Author Topic: LEDWiz Command Line Program  (Read 2571 times)
gigsgtox
  • Last login:February 25, 2009, 01:52:34 pm
« on: February 20, 2009, 01:20:38 pm »
I am using the LEDWiz to open and close a series of 5V valves.  Creating the .LWA files for each individual sequence is easy using notepad, however, I need a program to execute the LWA files.  As has been said, the included LWSend does not work, and searching the forums I have found a few which seem like they would (SwiftLED), but they are no longer being hosted.
What would you recommend for such an application?  As I said, I am looking for the easiest command line interface for running an LWA file a single time, rather than in a loop.
Thanks so much for your help.
headkaze
  • 0x2b|~0x2b?
Re: LEDWiz Command Line Program
« Reply #1 on: February 21, 2009, 05:13:40 am »
It's a bit old but it might be suit your needs. LEDWizLighter & LEDWizGen
gigsgtox
« Reply #2 on: February 21, 2009, 09:49:15 am »
Thanks, I'll begin experimenting.  Tell me if I'm wrong, but it looks like I can assign each LW output to one of the "Available Controls", but how do I specify the length of time each one is left on?  Thanks for your quick reply
arzoo
  • Last login:January 26, 2025, 08:51:53 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #3 on: February 24, 2009, 08:30:06 am »
Check out LEDBlinky. It can run .lwa files from command line --> LEDBlinky.exe <.lwa>
You can also use the animation editor rather than notepad to create the sequences - it creates .lwax files (xml version of lwa).
Robots will kill you.
Arcade Addiction
gigsgtox
« Reply #4 on: February 24, 2009, 08:20:38 pm »
Thanks so much, LEDBlinky works great!  Now the only thing left to do is figure out how to tell it to run a lwax file once rather than looping.  Or do I need to put a long pause as the last frame of each file and then run the "Animation Stop" command during the pause time frame?  It doesnt look like a single loop functionality is built in but I wanted to check.  Thanks again.
headkaze
  • 0x2b|~0x2b?
« Reply #5 on: February 25, 2009, 06:51:32 am »
I didn't realise LEDBinky worked via command line. Thats good to know :)
arzoo
    • LEDBlinky
« Reply #6 on: February 25, 2009, 09:37:09 am »
It actually does have a single loop function - but I never exposed that via the command line option. If it's not too involved, I'll add that to the next release - which is currently in beta.
Arcade Addiction
gigsgtox
« Reply #7 on: February 25, 2009, 10:45:10 am »
Looks like ya have thought of everything.  Thanks again for your help.
