Author Topic: 31KHz Monitor Question  (Read 2737 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: February 19, 2009, 06:58:18 pm »
Can I use a 31KHz to play all those 15KHz games? Cant seem to find a 15KHz and I see this 31KHz in ebay so I want to get it so I can finish my cab. Thnx!
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
Kevin Mullins
    • Me on Myspace
Re: 31KHz Monitor Question
« Reply #1 on: February 19, 2009, 07:25:22 pm »
You do realize that 31khz is just a computer monitor right?
And yes, you can "play" those games..... just not at their native resolutions which are generally much lower.
Ortizimo
« Reply #2 on: February 19, 2009, 08:01:18 pm »
no i did not knew that... :dunno I see a 29" arcade monitor @ ebay...here's the link...this is what I wanted to buy...http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=380105129466
what do you think?
thnx 4 the reply.
Kevin Mullins
    • Me on Myspace
« Reply #3 on: February 20, 2009, 01:44:34 am »
I don't personally know much about them, but what I did find was that they seem to be TRI-Sync which means they will do 15khz - 25khz - 31khz resolutions. So it should run anything you want without much trouble.
Looks like a nice monitor and it's new. (looks like a good price too)
Might want to ask the seller what the frame dimensions are to be sure it'll fit in whatever cabinet you plan to build.
Sanwa - 29PFX 15/24/31khz Pure Flat
Maybe someone else here knows more about them and how reliable they are.
grantspain
« Reply #4 on: February 20, 2009, 01:56:53 am »
sanwa pfx are the best tri sync money can buy :D
Ortizimo
« Reply #5 on: February 20, 2009, 07:21:27 am »
thx u all 4 ur incredible help! ;D one last question....would i need an Arcade VGA card or will any 256mb card will do? Dont want to damage this thing....thnx!
« Last Edit: February 20, 2009, 07:26:18 am by Ortizimo »
ahofle
    • Arcade Ambience Project
« Reply #6 on: February 20, 2009, 05:12:15 pm »
Just make sure you set windows to 640x480 (31khz) before you hook it up.  If it ends up being a tri-sync and you decide to explore the native 15khz resolutions, then you will need either an ArcadeVGA or software like Soft15khz (and a compatible video card).
Ortizimo
« Reply #7 on: February 21, 2009, 07:55:20 pm »
awesome...thnx!
