Author Topic: Need a 33" Arcade Monitor for new Showcase Cabinet Kit from Mameroom  (Read 6414 times)
dskillz1
  • Last login:January 23, 2020, 03:04:13 pm
Can anyone recommend a 33" arcade monitor, (800x600 minimum) for a new Mameroom Showcase cab?  Thanks!
grantspain
Re: Need a 33" Arcade Monitor for new Showcase Cabinet Kit from Mameroom
« Reply #1 on: February 15, 2009, 12:26:52 pm »
have you tried contacting niemandisplays  yet,he may be able to sort something
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #2 on: February 17, 2009, 08:19:17 pm »
Highly unlikely you will find anything. The tube and yoke needed to do that resolution has been out of production for years.
Perhaps you will find it used??
If you wanted standard res I can do that have the tube and all parts in stock.
Sorry.
Rick Nieman
Rick@niemandisplays.com
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
MonMotha
« Reply #3 on: February 18, 2009, 09:19:08 am »
Kortek has/had a KT-3414DF model.  I think the viewable size on that was 32-33".  It's a larger version of the KT-2914DF that Betson sells.  It was used in In The Groove 2 and later Pump It Up GX cabinets.  However, PIU (ITG is out of production) recently went back to using 27" monitors, but they didn't give a clear reason.  The rumor is that they could no longer get the KT-3414DF from Kortek.  My PIU unfortunately has a different, VGA only monitor (I think it's a Tatung), so I can't provide much more info.
The KT-3414DF was CGA-SVGA, dynaflat tube.  A very nice monitor, but I'm told it retailed for close to $1500, and you'd likely have to have it shipped from Korea if you can still find one new.  There's a Kortek rep in the USA who may be able to locate one for you.
Oh, one other suggestion: if you're willing to accept interlace, you can do 800x600 on an EGA (medium res) display at around 72-75Hz.  You can also do it on a CGA (standard res) display at around 50Hz, but that'll flicker really badly, and you'll also likely have smudgy edges as that'll exceed the analog bandwidth of most CGA monitors.  Also, be aware that not all displays are specified for operation above 60Hz, so that may complicated the finding of a suitable medium res monitor.
« Last Edit: February 18, 2009, 09:28:47 am by MonMotha »
northerngames
  • Trade Count: (+18)
« Reply #4 on: February 18, 2009, 11:58:39 am »
the gateway destination VGA monitors do 800X600 maximum
DL31 DL33 DL36 not sure if they ever made a DL39
atxscarface
  • Last login:February 16, 2024, 06:40:56 pm
« Reply #5 on: October 01, 2014, 06:38:15 pm »
Im sure this is not relevant anymore....but just came across an Atari Showcase 33 cabinet that I am converting and have removed the original monitor. Accepting offers, haven't posted in the Buy/Sell section yet.
