Author Topic: Felt Pen Removal  (Read 2301 times)
Danno
  • Last login:Never
  • I want to Build My Own Arcade Controls!!
Felt Pen Removal
« on: March 04, 2002, 09:01:38 pm »
Hello,
Restoring an old Missile Command...
The nice rocket graphics on one  side of the cabniet has been colored in with black felt pen, is there any solution out there that will remove this, leaving the original paint.
Thanks,
Danno
PS: Still looking for Stargate/Defender joystick or parts listing to make my own.
« Last Edit: December 31, 1969, 07:00:00 pm by 1026619200 »
1UP
  • Token Junkie
    • 1UPArcade
Re: Felt Pen Removal
« Reply #1 on: March 04, 2002, 10:39:23 pm »
The safest way I know is to scribble over the marker several times with a DRY ERASE marker.  Apparently, "permanent" markers and dry erase use the same solvent base, but the dry erase is, of course erasable!  I've used this to get Sharpie off my monitor when Windex failed.  (Don't ask why I wrote on my monitor with a Sharpie...   :-/
Immediately after scribbling over the old marker, wipe away the dry erase with dry paper towels or scrap cloth.  You may need to repeat this a few times.  This will probably only work if the printing underneath has a slick finish.  If the surface is porous and the pen has soaked through, I doubt anything else will get it off.
Good luck.
My other job...
matt
  • Last login:December 20, 2003, 04:26:09 pm
  • Someone who just loved arcade games
« Reply #2 on: March 05, 2002, 05:46:21 am »
Dan, I know it sounds crazy but I have had some good luck with plain old WD-40 to remove marker sometimes, as well as adhesive residue. don't use to much elbow grease or you could scuff the graphics, just let it set a little and wipe, won't cost much if it don't work! Take Care Matt
Ken Layton
  • Guru
  • Technician
Re:Felt Pen Removal
« Reply #3 on: November 02, 2003, 02:12:19 am »
Common rubbing alcohol from the store/drugstore works well. Get the 99% strength.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #4 on: November 02, 2003, 09:15:17 pm »
Why did you write on your monitor with a sharpie?
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
Re:Felt Pen Removal
« Reply #5 on: November 03, 2003, 01:18:21 pm »
I've got a bottle of solvent designed to remove pricing ink (remember when they used to stamp prices directly on objects in the supermarket?)
It takes permanent marker off any surface. I doubt it's still available though.
I like the tip on the dry erase marker, but I suppose afterwords it's best to discard the marker, lest anyone ruin their dry erase board. :-0
Bob
dphirschler
  • Last login:February 10, 2021, 10:32:54 am
    • dphirschler homepage
Re:Felt Pen Removal
« Reply #6 on: November 04, 2003, 10:44:37 am »
The dry erase trick works on glass and even plastic, but you have to be careful on porous material like wood.
Darryl
soslo
  • Last login:March 10, 2012, 03:23:36 pm
  • The Governator
    • My website does not have a name yet
Re:Felt Pen Removal
« Reply #7 on: November 04, 2003, 04:35:55 pm »
Another "I know this sounds crazy method" - use carbureator cleaner. It does wonders with permanent marker and melamine...though it migh work the underlying paint to...
5 MAME cabs and counting...
Ever wonder what full side art looks like?
http://www.aaronmurray.com
