Author Topic: I've peeled cpo's off metal, but now wood seems to be more of a pain, Any Ideas?  (Read 3057 times)
mrclean
  • Last login:August 10, 2022, 08:30:36 am
  • World Record Holder for Gun Smoke Dedicated & MAME
    • Guscade
I'm having a tough time peeling off a control panel overlay that was on wood for 20+years any methods to use ? It just cracks in little tiny sections, any type of chemical or solution I should try ?
2,370,650 Gun.Smoke
Pac-Fan
  • Last login:February 05, 2014, 09:30:12 am
Gell-based paint stripper.  Doesn't leave any 'oily' residue like Goo-Off / other stuff so the new overlay will still stick.
You will need to rough up the plastic to let the chemicals get in underneath (use a wallpaper "tiger" device to poke thousands of holes through the plastic), or you can use a wide putty knife to get under it as well and let the stripper get under the leading edge bit by bit.
mrclean
    • Guscade
I heard something about an oven method, should get my panel any day now. temperature and time to bake my panel haha ?
2,370,650 Gun.Smoke
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
I would use a heat gun to warm it up a bit to get it pliable. An oven not so much -- pr0k has pointed out that when polycarbonate burns it releases cyanide gas, which is "really not that good" (although it may be doing that when I heat it with my heat gun).
Working: Not Enough
Projects: Too Many
Progress: None
mrclean
    • Guscade
I don't own a heat gun, what about a hair dryer ?
2,370,650 Gun.Smoke
Ginsu Victim
  • Comanche, OK -- USA
You have to hold it closer, but it worked for me.
Pac-Fan
Heat guns are available for $7.99 at Harbor Freight quite often, $9.99 almost all the time.
mrclean
    • Guscade
well it turned out that the control panel was metal / and wood. Just used paint thinner / stripper it seemed to help alot.
2,370,650 Gun.Smoke
Zakk
  • Last login:Yesterday at 10:14:36 pm
Acetone eats through almost anything in my experience.  Even dead hookers.
We really lost a good community service when stingray left.  DIY dead hooker disposal is a pain.
CheffoJeffo
Bees are cool too ... just sayin ...
Working: Not Enough
Projects: Too Many
Progress: None
Stingray
Acetone eats bees as well as dead hookers and control panel goo. It also makes potent jell-o shots, please try at your own risk.  ;D
-S
