Author Topic: hooking up leds to 12v or what???  (Read 2364 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: March 05, 2002, 06:53:00 am »
In reading down about the translucent microswitch led thingy I would like to get pink microswitch buttons and light them up...i am going to use a keyboard or joypad hack for this project so i will power the leds from the pc power supply...........any ways long story longer I canneot remember how to hook leds up without blowing them....i.e. resistor wise...the whole shibang..
thanks
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
American Laser Games Wrapper
O2em Rom Utility
aramis
  • Last login:November 26, 2002, 09:24:04 pm
  • mame cab ALMOST done!
Re: hooking up leds to 12v or what???
« Reply #2 on: March 05, 2002, 07:13:33 am »
I haven't dealt w/ LED's in a long time, but here is what I remember....  :)
I would use the 5V instead of the 12V of the PC power supply. Then, throw a 1/4W resistor in series with the LED so you don't burn it out. (Remind me...don't normal LED's run on just 2-3V DC?) You may have to experiment w/ different resistor values to try to get the brightness just right, but start w/ a 1K or so. IIRC, led's are current driven, not voltage driven so just remember the ol' V=IR formula. Depending on the number of led's (and total resistance) you might have to keep an eye on the total current draw from your +5V supply.
There are some super-bright BLUE led's available that run on 5V...they are like $5 each, but might look pretty cool, depending on the button color.
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
« Reply #3 on: March 05, 2002, 08:06:57 am »
Minimum voltage varies by the LED color and design, but all requre under 5 volts.  You should be able to run most from 12v, but you will need a higher ohm resistor.
ir/red 1.2-1.5v
green 1.5-2v
blue/uv 3.5-4v
