Author Topic: Newbie needs help and advice  (Read 2113 times)
bigvic
  • Last login:September 24, 2009, 07:20:38 am
« on: February 03, 2009, 07:10:03 am »
Hi guys
l need to build an mp3 computer jukebox. I haven't decided wether to go for a touchscreen or button for controlling it , so can anyone recommend software, the touchscreen/touchscreen software, how to interface the control buttons with the computer, the min requirements for the computer, and/or anything l will need to know to setup my jukebox, and of course l don't want to spend a million dollars.
The sound part of it l am pretty right. Thanks
Bigvic
  • Last login:Today at 02:56:06 pm
Re: Newbie needs help and advice
« Reply #1 on: February 05, 2009, 02:04:06 pm »
You are going to have to be way more specific with your request.  Your post basically reads "please tell me how to build a jukebox." Check the WIKI for all of the juke software out there and test them out.  Freebox gets a lot of good publicity around here (I can recommend it).  As for everything else, spend some time here reading the different project threads - loads of people have built jukeboxes of all different shapes and sizes.  Once you decide what you want people we can help you with specific questions.  Good luck!
unclet
« Reply #2 on: February 05, 2009, 02:38:17 pm »
If you want buttons on your jukebox to control things you most likely would want to go with a keyboard encoder which is a hardware board which translates a button press into a specifically mapped keyboard key.   Search for IPAC and KeyWiz for a couple of ideas.
If you get a touchscreen monitor then you would not need to have any buttons to control the software so you would not need to get a keyboard encoder since you would simply be using your finger to make selections, etc.    I have an ELO Nec 17" touchscreen monitor and it works great for me.   After hooking up the monitor you will need to install the ELO touchscreen drivers which you can get from ELO's website.   There are other touchscreen monitors existing, but I have never tried others.
If you decided to install a trackball and two buttons representing  right/left mouse click buttons (or simply use a real mouse) then you most likely do not need a keyboard encoder or a touchscreen monitor at all.
The minimum requirements for a jukebox computer depends on what you are using it for.  My jukebox plays videos as well as audio files so my computer had to be fast enough to play videos smoothly (ie: without jumping through the video) and have enough space on the harddrive to store video files as well.  Are you going to back up all of your music files once it is all setup properly to run on the jukebox software you selected?  If so, then an additional harddrive might be required to be purchased.
Look through the jukebox software available (read the jukebox wiki to see a list and links) an try the ones which appeal to you.  I would recommend looking at screen shots of the software to get a feel for the software which looks good, then read up about the software to determine which features the software has in it which you might want to be supported (dual monitor support, remote internet connection, kareoke, scrolling lyrics, etc.. etc ...).   Then look at price and determine if you are willing to pay for software or if you want to use free software.   Determine if the software should run on Windows, Linux, DOS, etc...
After you build the cabinet (or whatever) for your jukebox then installing the software and setting it up is pretty much simply placing the files in a supported directory format used by the software you have chosen.  Also, you might need to update your audio files to have ID3 Tag information embedded into each audio file if the software required this as well.   If you read the software's description you should be able to understand what would be required to set up the software for use.   You can even simply set up 10 songs only in the required format just to test the software out first to decide which software you ultimately will use.
Hope this helps a bit.
fredster
  • Grand Prophet of Arcadeology
  • Last login:February 16, 2019, 04:28:53 pm
  • It's all good!
« Reply #3 on: February 06, 2009, 04:55:44 pm »
I advise to go cheap and easy to start.
Get AJ8 and use it.  It's free. It's easy. It works.
Then either buy a keyboard encoder or hack a keyboard.  I see those encoders going for like $20 on ebay now.
Find a box and put it in it.  Paint it up any pretty color you want, any shape.  Look at the examples page. Put some lights on it, put the buttons in front, and hook it up from the back of the computer to some cheap surround sound system.
King of the Flying Monkeys from the Dark Side
