Author Topic: weighing down an arcade stick.  (Read 1688 times)
Broken
  • Last login:October 22, 2012, 04:29:02 pm
« on: February 01, 2009, 03:53:29 pm »
how do you guys do it?
i prefer stiff sticks so i need a heavy stick to keep it sturdy. do you guys add weights to your sticks?
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: weighing down an arcade stick.
« Reply #1 on: February 01, 2009, 04:02:55 pm »
minimum
10x< joystick force to engage - stick weights
competion 250g - stick 2500g
P360 350 - 3500g
 :angel:
Broken
« Reply #2 on: February 01, 2009, 04:22:32 pm »
minimum
P360 350 - 3500g
 :angel:
3.5kg doesnt seem heavy enogh, i really want that genuine arcade feel without getting an actual arcade cab.
Jack Burton
« Reply #3 on: February 01, 2009, 05:51:33 pm »
minimum
P360 350 - 3500g
 :angel:
That is assuming that you only use the minimum force to engage the joystick.  If I'm going to be doing a reversal DP in SF I'm probably going to exceed that 100x over.
Broken, are you playing on your lap or do you set your stick on the floor/table?
TOK
  • The Game Always Wins
« Reply #4 on: February 02, 2009, 05:44:11 am »
I attach all mine to a 300 pound cabinet. They never move.  :)
Broken
« Reply #5 on: February 02, 2009, 05:51:51 am »
jack, i've never tried the floor, i usually play on my lap or a chair.
when i say heavy, i mean at leasdt 10kg's or more to weigh it down. i have professional bodybuilding plates (the type you get in gyms that cost hundreds, not the type you can buy from a regular store) which i never use. 5kg, 10kg and 20kg plates.
Jack Burton
« Reply #6 on: February 02, 2009, 07:28:59 am »
What sort of stick do you use?
kowal
  • Suzo 4ever
« Reply #7 on: February 02, 2009, 09:22:27 am »
more important surface from weight is stability
good gum on bottom
Broken
« Reply #8 on: February 02, 2009, 02:32:33 pm »
a really stiff old style suzo stick with sanwa buttons built from scratch. it broke down a while ago though.
regarding the weights, i want to connect some type of stand at the bottom of my stick which can be weighed down with the weights.
any advice on buying a stick would also help, something with a small throw preferably.
