Author Topic: Mala trouble  (Read 3449 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Mala trouble
« on: January 31, 2009, 10:13:52 pm »
Ok so im using a
Tree and this is what happens
When i select Mame and go into the list and try to leave i get this message and here is the error report:
2009/01/31  22:05:58.03   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02200000
2009/01/31  22:06:16.40   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02140000
2009/01/31  22:07:24.14   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02140000
2009/01/31  22:08:08.15   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02040000
2009/01/31  22:09:56.28   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 02340000
2009/01/31  22:10:46.29   Error: Object Class: TTimer, Object Function: LoadPicture, Exception Class: EAccessViolation, Exception Message: Access violation at address 004BBA58 in module 'MaLa.exe'. Read of address 020F0000
Please help
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Mala trouble
« Reply #1 on: January 31, 2009, 10:39:34 pm »
"try to leave" means what?  Go to another emulator?  Which emulator? Quit Mala?  How are you "leaving"?  Key press?  Mouse Click from the right-click menu?  You need to do some experimentation so you can give more details.
I'm thinking an incompatible screenshot, but that doesn't explain why it happens when you "try to leave".
« Last Edit: January 31, 2009, 10:46:23 pm by SGT »
wooowman93
Re: Mala trouble
« Reply #2 on: February 01, 2009, 10:29:08 am »
So when i enter into Mame (its on the top of my list) and then exit back into the emulator screen it crashes and does not do this with any other emulator
wooowman93
Re: Mala trouble
« Reply #3 on: February 01, 2009, 10:34:05 am »
Ok i also made it so mala displays the console or arcade machine picture when it is selected by getting the pictures and putting them in the marquee folder then naming it as the emulator  that has something to do with it
wooowman93
Re: Mala trouble
« Reply #4 on: February 01, 2009, 11:16:09 am »
This only happens when control panel and marquees are turned on
SGT
Re: Mala trouble
« Reply #5 on: February 01, 2009, 11:29:59 am »
Mala is not compatible with certain types of images. RGB images do not work.  Either your marquee images or control panel images are crashing Mala.
http://forum.arcadecontrols.com/index.php?topic=88699.msg932332#msg932332
wooowman93
Re: Mala trouble
« Reply #6 on: February 01, 2009, 11:33:35 am »
So what does it need to be put into "CMYK"
wooowman93
Re: Mala trouble
« Reply #7 on: February 01, 2009, 12:18:08 pm »
Changed to "CMYK"
But still doesn't work
SGT
Re: Mala trouble
« Reply #8 on: February 01, 2009, 01:19:58 pm »
Its all in the thread that I posted.
wooowman93
Re: Mala trouble
« Reply #9 on: February 01, 2009, 05:11:24 pm »
The Problems has nothing to do with the type of pictures
SGT
Re: Mala trouble
« Reply #10 on: February 01, 2009, 05:14:48 pm »
You deduced this how?  You turn off control panel images and marquee images and the problem goes away.  Yet it has nothing to do with the pictures?  If its not indexed color, it will crash Mala.  Are there other details that you haven't posted?
« Last Edit: February 01, 2009, 05:19:18 pm by SGT »
wooowman93
Re: Mala trouble
« Reply #11 on: February 01, 2009, 07:06:51 pm »
Ok i think it has something to do with mame only having having cp and marquee pictures that crashes it
