Author Topic: Mala is Messed  (Read 3198 times)
wooowman93
  • Last login:September 04, 2014, 03:56:02 pm
Mala is Messed
« on: January 31, 2009, 01:10:30 pm »
Ok my mala file is messed up it was working fine but it wont even start mame and a fresh Install is even more messed up as it won't even load up my skin
I need help please
loadman
    • MaLa
Re: Mala is Messed
« Reply #1 on: January 31, 2009, 03:21:57 pm »
I need help please
Hmm How is anyone supposed to help you with no real details  ???
Have you looked at the logs, looked at the MaLa Wiki, malfe.net Webpage help, serached this forum for the symptoms , What do you consider to be a fresh install ?
I suggest you try another FE  :dunno  As I fear this is not a FE you are coming to terms with?
« Last Edit: January 31, 2009, 03:48:18 pm by loadman »
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
Re: Mala is Messed
« Reply #2 on: January 31, 2009, 05:37:59 pm »
Loadman, you're being a little harsh.
wooowman93, from the command line, start mala like this:
mala.exe /run /unmessed
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
wooowman93
Re: Mala is Messed
« Reply #3 on: January 31, 2009, 06:41:54 pm »
It started working after i took off fades don't know why
loadman
    • MaLa
Re: Mala is Messed
« Reply #4 on: January 31, 2009, 11:47:06 pm »
Ummon
  • Trade Count: (+13)
Re: Mala is Messed
« Reply #5 on: February 02, 2009, 06:52:52 pm »
Yo. Chocolate.
Stephen Hawking
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Mala is Messed
« Reply #6 on: February 03, 2009, 05:00:39 am »
i tried mala.exe/run/messed to try and emulate the problem but it worked fine, i then ran mala.exe/run/unmessed just to be sure I hadnt upset anything.
