March 02, 2026, 02:11:06 pm
I wondering if there's a concensus on the best current DS flash cart. Divineo has the R4 and CycloDS listed for $20 and $48 respectively. Micro SD cards cab be had fairly cheap so the R4 seems like a deal. Is there something I'm missing?
That's good to know. It looks like both the R4 and Acekard are SDHC compatible so I think I'm going to try the Acekard (the price is right).
Quote from: somunny on January 27, 2009, 01:37:57 pmI wondering if there's a concensus on the best current DS flash cart. Divineo has the R4 and CycloDS listed for $20 and $48 respectively. Micro SD cards cab be had fairly cheap so the R4 seems like a deal. Is there something I'm missing? The R4 is not supported anymore, and the main advantages of the CycloDs are real time saving and slow motion.
The price on dealextreme shows up as 19.99 + free shipping. Where's the $11 price at?
Top Toy is even less
Two of these are nice to have since they outlast the stock and it is definitely an upgrade for longer play time.http://www.dealextreme.com/feedbacks/BrowseReviews.dx/sku.3840They also have a external USB dock that you can plug the battery pack in to charge it while the other is in the DS, but they're out of stock. The external charging dock is also a plus to have if you're into playing the ds for hours on end and need another cheap charger that only needs the battery to plug into it to work/charge.They also have a corded external power supply brick, but I don't know how well they work or how long the cord is. I don't think playing one with a short cord on a power brick connected to it would be all that great anyhow if that was the case.
Quote from: northerngames on February 01, 2009, 02:35:39 pmTwo of these are nice to have since they outlast the stock and it is definitely an upgrade for longer play time.http://www.dealextreme.com/feedbacks/BrowseReviews.dx/sku.3840They also have a external USB dock that you can plug the battery pack in to charge it while the other is in the DS, but they're out of stock. The external charging dock is also a plus to have if you're into playing the ds for hours on end and need another cheap charger that only needs the battery to plug into it to work/charge.They also have a corded external power supply brick, but I don't know how well they work or how long the cord is. I don't think playing one with a short cord on a power brick connected to it would be all that great anyhow if that was the case.Message fixed.Mix in some periods dude. I had to read your message a few times before I could semi-understand what you were talking about.
