Author Topic: Game listing shifted too far down?  (Read 2114 times)
mattred
  • Last login:January 28, 2009, 11:32:35 am
« on: January 26, 2009, 10:15:07 pm »
Sorry I can't get screenshots right this second, but hopefully someone knows how to fix this in the meantime. Basically on all the different skins I've tried using, the game lists are not lining up with the elements of the skin. IE, the selected game should be in the middle on top of the "selected game" element part of the background (a blue bar in one of the cases), but it's actually further down than it should be. The rest of the list is also too far down, and goes past the containing box part of the background. Even the snaps seem to be shifted downward. This is in every single skin I've tried so I'm wondering if there's a setting in Mala that applies to all the skins that is causing this. Screenshots of this problem hopefully to follow soon.
loadman
    • MaLa
Re: Game listing shifted too far down?
« Reply #1 on: January 26, 2009, 10:35:37 pm »
Have you your screen rez at an appropriate resolution for the layout(s) you have chosen?
