Author Topic: Just bought a router and table but now im lost........  (Read 3357 times)
SpeedEng
  • Last login:May 26, 2015, 01:31:42 am
  • one day I will finish
« on: January 26, 2009, 06:42:38 pm »
ok I got off my lazy butt today and picked up a router and table off of good ol-C.L.
(craftsman 1.5hp router 1/4inch)
now im lost
what bits do I get??
I stopped by sears and was completly lost when I took a look at all of the bits :dizzy:
(I really thought the ppl working there would be of some help but they were lost like me)
not sue if you need these details
im tryin to whip up a bartop using mdf 1/2-5/8 wood (maybe plywood if it's easier)
the build is more of a testrun than the actual build(as you can tell I have no skill with woodworking  :dunno) so I just wanna learn how to use the router properly
any help would be greatly apreciated!!
severdhed
  • RIP Dinosaur Hippo
Re: Just bought a router and table but now im lost........
« Reply #1 on: January 26, 2009, 08:24:13 pm »
well, i just recently bought a router too..and they are AWESOME!!!
i just started playing around on some scraps before i start my new panel...the bits i plan on using are:
1/16" slot cutter - for tmolding
flush trim bit - cutting plexiglass, making duplicate wooden/mdf panels
standard straight cutting bit for recessing the mounting plates on joysticks and trackballs
that should get you started
Virge
  • Last login:June 02, 2009, 10:17:57 pm
« Reply #2 on: January 26, 2009, 10:05:31 pm »
I just bought one yesterday also.  Prices of bits are scary at most stores.  I got the bits mentioned above from http://www.mlcswoodworking.com/.  Got 5 bits for the price of two at Lowes.
Chadwick
  • Last login:January 11, 2010, 03:23:34 pm
« Reply #3 on: January 27, 2009, 05:09:46 pm »
Oh boy...
Please be aware that when it comes to router bits, you get what you pay for.  Cheap bits are cheap for a reason.  Do you want to take a chance with sharp carbide spinning at 18,000 rpm or faster?
The list above is a good starter set:
-Slot cutter assembly: 1/16" Kerf slot cutter, arbor assembly, and bearing - bought in 3 separate pcs or sold complete
-Flush Trim Bit - get a 2-flute, carbide tipped flush trim bit with 1/4" shank, 1/2" Diameter, and 1" Cut edge length, bottom ball bearing.
-Straight Plunge - get a 2-flute, carbide-tipped bit with 1/4" shank, 1/2" Diameter, and 1" cut edge length
Those 3 bits will do most of the operations you'd need to do when building an arcade cab.
Encryptor
  • Trade Count: (+34)
« Reply #4 on: January 27, 2009, 08:12:17 pm »
I've seen this set in their catalog but just haven't gotten around to buying one yet. For the average user who only uses their router once in a while I think it would do fine at a great price.
http://tinyurl.com/d395cq
Harbor Freight also sells a couple of different sets.
Encryptor
TOK
  • The Game Always Wins
« Reply #5 on: January 30, 2009, 09:58:51 am »
Oh boy...
MLCS is a good place, they don't sell Harbor Freight type crap.
SpeedEng
« Reply #6 on: January 31, 2009, 07:12:00 am »
I ended up getting vermont american bit's
as for the harbor freight stuff. I think they sell some ok tools.
I usually purchase tools that I dont use too often from them
they held up pretty good
