Author Topic: Daphne Scores  (Read 1870 times)
FrizzleFried
    • Idaho Garagecade
Daphne Scores
« on: January 26, 2009, 04:41:30 pm »
I seem to recall reading somewhere that there is a way to display scores for DL, DL2 and SA in daphne?   Anyone know how that is done?
brian_hoffman
  • Last login:July 02, 2011, 09:02:20 pm
Re: Daphne Scores
« Reply #1 on: January 26, 2009, 04:59:25 pm »
yea its like -useoverlaysb or something.
If you use daphne loader turn on the scores in the config for the games. Those you listed are the only ones that have those options. Then check the daphne log so you can see the exact command givin.
TAG
  • Last login:May 23, 2014, 05:52:05 pm
Re: Daphne Scores
« Reply #2 on: January 26, 2009, 05:05:35 pm »
You can do it using a real scoreboard, or with an overlay from the command line (-useoverlaysb <overlay number>).  I think it's also an option in the configuration menu, so you can turn it on there and then check the log for the correct command.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
TAG
Re: Daphne Scores
« Reply #3 on: January 26, 2009, 05:09:14 pm »
Doggone, I don't type fast enough!  At least the part about the real scoreboard saves me from having posted a complete repeat of Brian's post. :cry:
-- Dirk Gently
brian_hoffman
Re: Daphne Scores
« Reply #4 on: January 26, 2009, 05:19:31 pm »
Hahahaha!! Its cool man. I cant remember teh exact command per game. I know its -useoverlaysb 0 r 1 depending on the game and it does matter as the command wont work the same way for all games.
On a side not I wonder what MAMEDEV plans are when it comes to emulating the scoreboard.
HMMMMMM
Ginsu Victim
  • Comanche, OK -- USA
Re: Daphne Scores
« Reply #5 on: January 26, 2009, 06:07:15 pm »
Removed the S from "https" in the link
http://www.daphne-emu.com/mediawiki/index.php/Scoreboard
