Author Topic: a little help on my arcade monitor  (Read 3844 times)
mcdeez
  • Last login:October 10, 2011, 01:11:19 pm
« on: January 23, 2009, 10:09:37 am »
My 25" arcade monitor is turning a purple/red(only color i know is missing for sure is yellow) after about 5 min. the cabinet its in prevents me from knowing the model unless i take the monitor out. does this sound like a cap kit or do i need to try to find another monitor.
mcdeez
Re: a little help on my arcade monitor
« Reply #1 on: January 23, 2009, 10:14:04 am »
also i switched boards just to make sure and both do the same.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #2 on: January 23, 2009, 11:34:04 am »
How does that prevent you from being able to see the chassis?
I guess I'd have to see a picture of the cab.  We'll need to know what kind of monitor is in there.
mcdeez
« Reply #3 on: January 23, 2009, 11:51:58 am »
The cab only has openings in the front everything else is solid so i would have to take the monitor out the front of the case to be able to see the whats behind it.  Its kinda difficult to get it out by myself so i have to wait till this weekend to get a little help.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: January 23, 2009, 12:41:19 pm »
You should read this first:
http://forum.arcadecontrols.com/index.php?topic=62016.0
SirPeale
« Reply #5 on: January 23, 2009, 01:22:56 pm »
I gotta see pics of this cab.  Most every cab I've seen has some kind of access to the monitor, so at the very least you can make adjustments.
Kevin Mullins
    • Me on Myspace
« Reply #6 on: January 23, 2009, 01:38:55 pm »
Could be one of them Die Hard type cabinets.
And a pic of the problem would be good if you can..... the description could be a couple different things.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #7 on: January 23, 2009, 07:28:37 pm »
ur green is dropping out .
could be a weak crt . faulty drive xistor. loose connection(s).  all the above or different.
visual inspection on the foil side of the neck pcb is warranted.
qrz
Tenn_pin
  • Last login:January 01, 2014, 06:57:02 pm
« Reply #8 on: January 25, 2009, 05:12:35 pm »
It is difficult to see the back side of a Tekken 3 since the cabinet does not open from the back. That is the WG25K7000 that I blew the cap in last week.  It had fluctuating colors, but now is fine.
