Author Topic: Yellow Dog Linux 6.1 (PS3) Help  (Read 7689 times)
Hunk_4TH
  • Last login:January 21, 2026, 09:48:13 pm
  • I DON'T ALLOW VANDALISM IN MY STOOOOOOOOOOORE!
« on: January 21, 2009, 06:18:49 pm »
I just got YDL 6.1 install on my PS3 everything is running smooth! Including Mame I think it's SDL Mame. Anyway I downloaded and installed this frontend http://www.mameworld.net/mamecat/ because I couldn't get Wah-Cade setup correctly. The problem I'm having is the frontend wants me to locate the Mame executable file but me being a Linux newbie I can't for the life of me locate this file.
In the Mame folder located in Usr/Share all is in there are roms folder and Mame/ini. Can anyone help? :(
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
Re: Yellow Dog Linux 6.1 (PS3) Help
« Reply #1 on: January 28, 2009, 07:45:43 am »
Open a terminal and type the following:
locate sdlmame
This should tell you where it is located. It will throw up a few things that match, but hopefully not too many. On my Ubuntu 8.10 box, it's located in '/usr/games/sdlmame' (however, the config folder is '/usr/local/share/games/sdlmame/roms', not what you have).
If it doesn't find it, you may need to update the database:
sudo updatedb (or su updatedb) - I don't know if YDL uses sudo or su normally. Then try locate sdlmame again.
« Last Edit: January 28, 2009, 07:47:21 am by captainpotato »
Hunk_4TH
« Reply #2 on: January 29, 2009, 12:34:39 am »
locate sdlmame
Hey there, thanks for the help! Those commands did work but only turned up some txt files it's kind of strange. When I open up a terminal and type in mame it loads up mame perfectly. Any ideas?
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #3 on: January 29, 2009, 12:55:28 am »
Yep, try: locate mame
The executable must be called 'mame' on your machine, not sdlmame.
Hunk_4TH
« Reply #4 on: January 29, 2009, 01:06:30 am »
Thanks man that worked! I really appreciate the help :)
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #5 on: January 29, 2009, 01:33:08 am »
No problem - it's nice to see a few more machines running Linux :)
  • Last login:Today at 10:50:22 am
« Reply #6 on: January 29, 2009, 06:59:45 am »
I don't know about you, but I found YD linux on the PS3 to be more trouble than it's worth.  What do you think of it so far?
Hunk_4TH
« Reply #7 on: January 29, 2009, 01:55:40 pm »
Oh I agree!! :)
Well I had some trouble getting it installed at first. But after that everything seemed to go pretty smooth. I do have one a little problem with MAME though. Seems the version I'm running is 128 U3 and when playing Mortal Kombat it runs perfectly but after awhile it'll get all choopy and slow :(
Dartful Dodger
  • Newer isn't always better.
« Reply #8 on: February 10, 2009, 11:41:48 am »
Can you watch downloaded Netfilx on a PS3 through Linux?
