Author Topic: Announceing the Artistic Series from Kaytrim's Kustoms  (Read 2865 times)
Kaytrim
  • I'm too nice a guy
« on: January 21, 2009, 12:01:43 am »
Case made from Waterfall Bubinga and Spalted Curly Maple
Sanwa JLF
Seimitsu Buttons
Toodles Cthulhu board.
This case is not for sale at this time. More information can be found in my blog.
Franco B
Re: Announceing the Artistic Series from Kaytrim's Kustoms
« Reply #1 on: January 21, 2009, 07:00:06 am »
Looks great Kaytrim :)
I preusme the dust washer bush worked ok then?
Kaytrim
« Reply #2 on: January 21, 2009, 09:49:01 am »
With a little modification on my part the bushings work well.  I had to add a brass pen tube to the inside of the bushings you made.  Otherwise the holes were too large for the pen mandrel.  My fault not yours.  I also used the Veneer punches you made for me.
Thanks for your work,
Michael
« Reply #3 on: January 21, 2009, 11:20:49 am »
Sweet job there Kaytrim.
I like the woodgrain in the pushbuttons.
Gatsu
« Reply #4 on: January 21, 2009, 11:32:24 am »
A beautiful stick for sure man. Great job.
I'm just not a fan of the wood-grain sticks. I like the plastic or metal look.
Kaytrim
« Reply #5 on: January 21, 2009, 12:28:10 pm »
To each his own buddy.  Keep doing what you like best and you will do your best work.  :cheers:
Michael
kizer
    • Links4jeeps.com
« Reply #6 on: January 21, 2009, 05:42:40 pm »
Nice stick. Not to sound like a critic because I don't know the effort involved but.
Could the screws be counter sunk? Or maybe screwed from the inside to hide them? Looking at the bottom well its obvious they couldn't be screwed from the bottom unless you used some kind of Helacoil gizmo.
My questions are meant as you shoulds just ideas of course.
I really like the addition of the little pieces of wood on the corners. Gives it some character.
Kaytrim
« Reply #7 on: January 21, 2009, 05:53:41 pm »
Kizer,
The top panel is only 1/4" thick so there is no real way to hide the screws.  I did counter sink the screws but they have a slight dome to them so still sit proud of the surface.  There are no sharp edges to the screw heads so I am not worried about anyone scratch their hand using this stick.
Thanks for the comments both positive and constructive.
Michael
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #8 on: January 29, 2009, 04:14:50 pm »
Looks good Kaytrim, nice to see you still building these:)  I plan on using the one you built for me alot more when sf4 comes out.
