Author Topic: mala front end  (Read 1397 times)
jessybr
  • Last login:December 25, 2016, 05:54:07 am
mala front end
« on: January 18, 2009, 05:48:14 am »
hey everybody
does anyone have any problems with mala and soft 15 khz
soft 15 khz does not switch to 15 khz because i cannot get my res in 640*480
and the refresh rate below 63 khz
is there a commandline for this problem??
i am using a mala frontend with scalable layout and the picture is al messed up
my videocard is ati radeon 9200
does any one have any tips??
or must i use a different frontend??
greetings from holland
Lilwolf
Re: mala front end
« Reply #1 on: January 18, 2009, 08:58:37 am »
I'm using mala, I thought you could tell it ANY resolution you wanted...
so get windows to ONLY allow the resolutions it can handle with soft15k... Then tell mala a 15khz resolution.
NOTE:  My monitor handles both, so I'm running 640x480 in the frontend... But I thought I told mala thats what I wnated... not the other way around.
retrometro
  • Last login:May 24, 2024, 09:11:44 pm
    • Arcade, mame, retro... and the gp2x.
Re: mala front end
« Reply #2 on: January 18, 2009, 08:46:23 pm »
i've been using mala on several machines and video cards.  i have my front end set to my desktop resolution and it's been 512x384, 640x480, 800x600 and several other ones over the years.  no problems.
-------- gp2x and retro... play it forever! ------------------------
http://www.youtube.com/view_play_list?p=0EE573E86D5A86E0
