Author Topic: Switching to MAME causes MALA to crash when using left/right to select emulators  (Read 1856 times)
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
All of a sudden GBA and MAME started causing MALA to crash when switching between emulators with the left/right keys. The error in the log was:
2009/01/17  12:40:06.48   Error: Object Class: TTimer, Object Function: DisplayMarquee, Exception Class: EListError, Exception Message: List index out of bounds (3026)
I took out the GBA layout, opened it in the mala layout editor, saved it and put it back in the main directory and that fixed the GBA issue, but MAME still does it. I can remove Mame's layout and Mala will use the default layout, but it still crashes anytime I try to switch to from MAME to another emulator with left/right keys (I can right click and pick any emulator I want without any problems)
Please help!!!
mcobit
  • Newbie
  • Last login:May 12, 2012, 12:05:22 pm
Has someone found a solution for this? It happens to me all the time and I want to get rid of it.
I have this problem with the playstation emulator layout and this error message:
Error: Object Class: TTimer, Object Function: DisplayVideo, Exception Class: EListError, Exception Message: List index out of bounds
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Hi,
 This is realy a question better posted in the MaLa forum..
It is fixed for the next release..
