Author Topic: driving games what would I need hardware?  (Read 1732 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: January 15, 2009, 03:53:52 pm »
I have a pole position wheel, shifter and pedal from a arcade cab.  I want to be able to play the most games possible.  I know I need a 270 wheel also.  I was told a pc wheel is way to go for a 270 wheel.  can I get apc shifter and pedals and just use the PP wheel along with the 270 wheel?  any suggestions for what brand to get?
daywane
  • GRRRR!
Re: driving games what would I need hardware?
« Reply #1 on: January 15, 2009, 07:23:19 pm »
for your Pole position you will need a opti pack get it here
http://www.ultimarc.com/optipac1.html
shifter and pedals will need a interface such as the I pac or keywiz
http://www.ultimarc.com/ipac1.html
or
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_80&products_id=199
Yes you could go with the pedals from the 270 wheel
I have 2 microsoft wheels these work fine
but the 270 wheel must be hooked up
see here
http://forum.arcadecontrols.com/index.php?topic=17666.0
some were in this board is instructions on how to mod a microsoft wheel into a 360 . I shall take a quick look.
I can not find it yet  :dunno
there is always the mouse hack and Microsoft Dual Strike USB  hacks for you Pole Position wheel also
vartech
« Reply #2 on: January 16, 2009, 10:49:02 am »
I have the ipac and optipac  on my arcade machine.  I guess I need to know about  Potentiometer vs encoders vs microswitches as they pertain to pedals shifters and wheels. This is what I know so far.
Wheels are encoder(360) and potentiometer (270) need two wheels since there is no all in one.
shifters are microswitches-  most games are high low, 4 speed and some have a turbo button.  I did not see a six speed shifter at happ so I think that a four speed would cover most games.  Please let me know if I am wrong and if a six speed would be better and where to find one.
Pedals (gas, brake, clutch)are potentiometer or microswitches no all in one so does this mean I need two sets?  can someone provide more info on this and how do potentiometers connect to a pc
My ultimate goal is to have a set up that I would cover the most games with limited switching.
severdhed
  • RIP Dinosaur Hippo
« Reply #3 on: January 16, 2009, 03:43:11 pm »
i dont have alot of experience with driving controls, but for your pedals...you go with pedals that have a potentiometer, so you get analog control, and you install a switch so that it activates when the pedal is depressed the whole way..that way it will work with both types of games.
mytymaus007
« Reply #4 on: February 11, 2009, 08:17:17 pm »
When you mean install a switch are you talking about adding a switch pedal or put a switch in with the potentiometer pedal
vidmouse
  • Last login:November 08, 2021, 10:13:41 am
  • Oop! Ack! Thppphbt!
    • Vidmouse's Arcade
« Reply #5 on: February 12, 2009, 08:33:51 am »
I'm in a similar boat right now and am intending to do a mouse hack on
my sci 360 wheel.  What I don't quite get is what games require 360
and why some require 270.  Seems if you can get 360 you can do it all??
Or is it just a matter of amount of control you have, like trying to use an 8-way joystick to play pacman (do-able, but harder, less enjoyable)??
Minwah
    • MAMEWAH
« Reply #6 on: February 12, 2009, 09:53:35 am »
No need!!
Go with potentiometer pedals yes, but do not add a microswitch. There is no need, Mame can map an analog input to a digital game input. Even if you want to use an emulator/game which doesn't have this functionality, you could just use JoyToKey.
Minwah
    • MAMEWAH
« Reply #7 on: February 12, 2009, 09:56:37 am »
Yes but...
Exactly. Playing eg OutRun with a 360deg wheel is possible and I suppose fairly ok, but not a patch on using the proper controller. Things like straightening up are not so easy with a 360deg wheel as it is not clear by the position / feel of the wheel where 'straight' is.
Get an arcade 270deg wheel...much better than creaky plasticky PC ones  :P
