Author Topic: Cheats wont work in mame UI Version 128  (Read 6984 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: January 14, 2009, 09:27:06 pm »
Anyone know why the cheats wont work in mame UI v.128.  I have the cheat dat file and selected enable game cheats in the micellaneous tab. Thanks
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: Cheats wont work in mame UI Version 128
« Reply #1 on: January 15, 2009, 12:17:43 pm »
I'm sure it's been stated before, but I'll say it again.
Beginning in 0.127 - MAME switched to a different format for cheats - XML files.  You can get the master pack still at Pugsy's Cheat Forum, here:
http://cheat.retrogames.com/forums/viewtopic.php?t=3110
Simply download and leave the CHEAT.ZIP contained therein in the same folder as MAME.  Using the -cheat trigger as before will allow you to select cheats like before via the menu.
rlemmon
« Reply #2 on: January 16, 2009, 12:31:54 am »
Thanks i'll give it a shot.  :)
rlemmon
« Reply #3 on: January 16, 2009, 05:02:34 pm »
Hmm I tried what you said it didnt work though, Thanks anyway
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« Reply #4 on: January 17, 2009, 03:06:19 am »
I did it and it worked fine. I think you need to unzip the first zip file. In there is a read me, another text file and a zip file. Put that zip file (like he said, don't open it) in your mame folder. I use command line, but you probably just have to navigate to that folder in the GUI.
rlemmon
« Reply #5 on: January 18, 2009, 12:53:34 pm »
dkubarek , I did what you said it worked great ! Thanks for all your help with this guys !   :notworthy: :notworthy: :cheers: :cheers:
dkubarek
« Reply #6 on: January 18, 2009, 12:57:34 pm »
awesome. I'm a noob so it's good to fix something since I've been asking everyone else to fix mine. I wasn't expecting the zip in the zip, either, and it had me stumped at first.
