Author Topic: 2 new layouts for Mala ::: Files Attached!  (Read 4700 times)
livelike
  • Last login:June 10, 2024, 02:20:59 am
« on: January 13, 2009, 06:04:03 pm »
Well I feel like I was lost, and then I found the light, well I mean, I found Mala ;D
I decided to make two custom layouts, that were just uploaded to Malafe.net (awaiting for approval). So hopefully they will be up soon.
The first is a very simplistic generic black layout, it can be used with any emulator. The second is a custom replica of Maximus Arcade, which I called "maxmame". It includes selection screens (for use with Mala Tree), for a wide variety of systems. Both are scalable 4:3, horizontal only layouts.
Note. The original images for "maxmame" and backgrounds were taken from MA, I do not take credit on creating these images, only for putting them together for Mala use.
Loadman, please let me know if you received OK the second file, as it was a 10MB upload.
Cheers.  :cheers:
I forgot, the attached snaps are pretty small size, I overwrote the bigger ones for uploading.  :banghead:
Edit. I did not receive response from Loadman, he´s probably busy. Anyway I uploaded both files, the black layout is attached at bottom. For MaxMame, you can download it from Mediafire (10.5 MB download):
http://www.mediafire.com/?msmmsxmm1mj
« Last Edit: January 16, 2009, 06:59:51 pm by livelike »
Bender
Re: 2 new layouts for Mala ::: Files Attached!
« Reply #1 on: January 18, 2009, 11:19:28 am »
do these animate like maximus?
livelike
« Reply #2 on: January 18, 2009, 07:51:12 pm »
No, they are static, I'm relatively new to the layout editor, so I went with the basics  ::). I planned to use the Mala tree in order to use the system photo and the cabinet background for the game lists. If somebody wants to help to make a complete MA replica including sounds and animations, it would be great :applaud:. I already have the images and sounds, if anyone is interested....
Loadman, you may upload these layouts to your site if you like them.  :)
« Last Edit: January 18, 2009, 07:54:13 pm by livelike »
loadman
  • Moderator
    • MaLa
« Reply #3 on: January 18, 2009, 07:57:40 pm »
I like, but I need you to submit them via the website please as it makes life so much easier.  ;D
livelike
« Reply #4 on: January 19, 2009, 05:20:46 pm »
Loadman, I uploaded the black layout with no problems, but I get a timeout message for "Maxmame" (its a 10MB upload), I already tried twice and get the same. I guess I this will be the only download place. In case you can manually upload the file the info is,
Layout name:
MaxMame
The description is:
• Horizontal view only
• Includes Fonts
• Includes 20+ systems
Your (Nick)Name:
Livelike
esplinter
  • Last login:November 22, 2009, 09:17:14 am
« Reply #5 on: November 12, 2009, 05:16:59 pm »
link is broken....    :-\
anyone can upload this again?
many thanks!
