Author Topic: UAII Monitor mounting system question....  (Read 1446 times)
DigitalAce7
  • Last login:June 08, 2012, 03:03:19 pm
« on: January 12, 2009, 08:50:19 pm »
Hi all,
I purchased the UAII kit and I also purchased the monitor mounting system.  I am having trouble fitting in a Wells Gardner D9800 monitor.  The main pieces of the monitor mounting system have holes that don't line up with the mounting brackets on the monitor.  I attached a pic  that hopefully illustrates the problem.  Also when I put the monitor into the cabinet, it doesn't fit flush.  The mounting brackets of the monitor don't allow the monitor to slide right in.  Its just a little bit too big for the mounting system.  Does anyone have any suggestions?  Thanks in advance.
     - DigitalAce7
