Author Topic: WGZ2798-U0FS08S RSDD27V D9810 monitor problem pic attatched  (Read 5930 times)
gabesword
  • Last login:July 06, 2011, 12:14:28 pm
« on: January 11, 2009, 06:06:22 pm »
Hello,
I have a WGZ2798-U0FS08S RSDD27V D9810 monitor which is a digital 27" flat CRT from Wells-Gardner.  For some reason that I haven't figured out it is now squishing the sides of the picture in.  Does anyone know what is wrong or how I could fix it?
I have attached a picture that better explains what I mean.  Notice the left edge.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WGZ2798-U0FS08S RSDD27V D9810 monitor problem pic attatched
« Reply #1 on: January 11, 2009, 06:32:55 pm »
classic pin cushion problem .  cap/xistor ?
i'll need to see a print before can give u specific prts to check......and its not on the wg site , yet ?
qrz
gabesword
« Reply #2 on: January 11, 2009, 09:19:53 pm »
Thanks for the response.
When you say you need to see a print, what print are you talking about?  Is there a way I can get that?
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #3 on: January 11, 2009, 10:43:49 pm »
Have you tried adjusting the picushion adjustment in your OSD menu?
gabesword
« Reply #4 on: January 12, 2009, 01:30:07 am »
How do I call up the on screen display?  WG didn't send any manual.  I would love to give it a try.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: January 12, 2009, 12:52:07 pm »
Apparently, Wells-Gardner does not have any manuals for this model yet. Contact tech support:
Technical Support
John Pruski
Technical Specialist
p:(800) 336-6630
p:(708) 290-2155
f:(708) 290-2200
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
« Reply #6 on: January 12, 2009, 01:20:44 pm »
You can have a look at the D9400 user manual on how to use the OSD menu, the D9810 works exactly the same.
http://www.wellsgardner.com/pdf/Service/D9400_D9410_MANUAL.pdf
gabesword
« Reply #7 on: January 12, 2009, 10:36:10 pm »
Thanks for the suggestions.  I have now tried the OSD with very little success.  The pincushion setting isn't helping much/at all.  I just bought the monitor in October, does anyone know what WG's warranties are?
Is there anything besides the OSD I can do to get rid of the pincushion. is there some sort of hardware fix I can do for it?
Ken Layton
  • Guru
  • Technician
« Reply #8 on: January 12, 2009, 11:05:53 pm »
Sounds like you got another one of the famous Wells-Gardner "bad right out of the box" monitors. Call tech support as I mentioned and see what they say. If what they tell you doesn't work then you'll get another monitor.
