November 24, 2025, 06:48:31 pm
I have seen examples of cps without mounting plates for spinners and trackballs. Is there a reason to have a mounting plate? Are the plates on the example cps just flush with the cp so they can't be seen?
the happs mounting plate I have has no visible carriage bolts, and if you recess the plate 1/16" you can cover it up with art, laminate, or anything else and it is invisible.
