Author Topic: Question regarding momentary square buttons and lighting, cockpit construction.  (Read 1206 times)
Warborg
  • Last login:January 11, 2026, 02:46:32 am
  • Personal text? Nah...
Ok, here's the deal...  My daughter and I are looking into building a flight cockpit "cab" with HOTAS controls in it (Saitek X52) and modeled after a MKII Viper from BSG, but I have a question about some controls that hopefully someone can have some input on.  I was thinking that I may want to put in a couple banks of square lit buttons (and some transparent labels in them to label the function) for various controls, such as power, or lighting, or programable functiontions via a keywiz or something for flight controls in whatever sim.  So the question is, does anyone know where I can get such momentary square illuminated pushbuttons, and is there a way to set it up to where if I push it once and it lights, and I push it again and the light goes out?  I don't think and on/off locking switch would work well with a keyboard encoder...
arzoo
  • Robots WILL kill you.
    • LEDBlinky
I don't know of any current software that does what you want (toggle on/off), but if you have any coding experience, there are function libraries available for both the LED-Wiz and PAC-Drive LED controllers. For a non-software option you could use low voltage relays.
Robots will kill you.
Arcade Addiction
Neverending Project
    • Arcade Fixer
Check out the U-HID. It is an extremely configurable USB controller where you can configure each of the 50 connectors to tasks such as push-buttons, trackballs, analog controls, lighting control, and you can configure a connector to be both a push-button and a toggle on/off led control.
