Author Topic: Mame resolution Help  (Read 1137 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: January 02, 2009, 11:57:00 am »
I just got a Wells Gardner 9800 and I have the old AGP AVGA card.  I tried using the Gavin Benson tool from Ultimarcs website and many games are cut off at the top and bottom.  I then tried the Mame Wah tool and have the same results.  Any suggestions?  I'm thinking something must be screwy in my Mame settings.  The MameWah tool also has Galaga (one of the games that cuts off) as 640x480 which seems strange.  Anyway, hopefully someone can point me in the right direction.
shiloh
  • Last login:May 10, 2016, 02:58:07 pm
Re: Mame resolution Help
« Reply #1 on: January 03, 2009, 01:51:13 pm »
I bet that the games that are cut off are probably all vertical games that uses 288 display lines (on a horizontal monitor).
In that case a tradeoff needs to be done. You can run them at 15k resolutions with 288 lines and a 51hz refresh rates and the games will run slower than original (if you use vsync or tripplebuffer) without being cut off OR it will run at 60hz refresh rate (original speed) but with only 240 lines and they will be cut off.
I didnt use much the Gavin Benson tool, but in the mame resolution tools you can tweak the "match refresh rate..." and "match resolution..." in the video mode selection menu. Alternatively you can select manualy the mode for those games to make it like you want.
If either of both option above doesnt fit your needs, you can try running these games at a 25K medium resolutions, they will not be cut off and will run at the original refresh rate but the display will be smaller with black border (ie, the game will not fill the screen). You must have installed the Ultimarc Trisync utilities to use resolution above standard.
hope it helps.
