Author Topic: EMS Topgun II Calibration Issue :-(  (Read 4340 times)
yuff
  • Last login:January 04, 2009, 12:18:52 pm
« on: January 01, 2009, 04:43:22 pm »
I am having calibration issues with a new Topgun II. I have a 42inch Dynex LCD and have tried the sensor bars mounted horizontally and vertically. When mounted horizontal, then mouse doesn't know what direction to go in and moves very erratic. I calibrated according to the manual (ABCDE order). When the bars are mounted vertically, I can get somewhat of a response in the direction i move the gun. If I move even one or two inches forward from the point i calibrated at, the mouse will move erratically and go in random directions. When I am calibrating the gun recoils and the red dot does not blink at me. This should indicate there is no IR interference. I have tried both the EMS and Smog drivers and they both do the same thing.
I also have a 19 inch lcd that I test it on. It seems to work a little better but I have to stand so far away I can barely see it. Even with the smaller monitor the mouse movevement is really shaky. I have tried standing as far as 10 feet away from the 42 inch lcd and it still seems to do the same thing. Any suggestions?
I am using Windows XP sp2 and just trying to get the mouse arrow to move correctly before trying to play any games. Also, I have tried unplugging all other mouse devices and same result.
Games001
  • Last login:January 13, 2024, 12:44:04 am
Re: EMS Topgun II Calibration Issue :-(
« Reply #1 on: January 01, 2009, 04:45:06 pm »
Do some searching through the forums.. the Top Guns are, at best, iffy.  I have never gotten mine on a LCD screen to act correctly.
yuff
« Reply #2 on: January 01, 2009, 05:01:42 pm »
I searched last night and tried about everything I could find but nothing seemed to help.  I have also tried to tape up my IR sensor on the tv and turned off all the lights and tried at night, still same thing. I guess I could try on a crt and see what happens or on my DLP...
Is there another lcd compatible lightgun out there? I couldn't find anything.
vetteguy112233
  • Last login:April 28, 2012, 12:15:24 am
« Reply #3 on: January 02, 2009, 10:39:53 am »
When I first got my Topgun II's, I set them up on my regular PC and they worked just fine. I hooked them up to my cabinet (crt monitor) and after a few times of calibrating they worked perfectly. BUT then I screwed things up and had to attempt to recalibrate and I still can't get them working.
Mine do the same thing, the pointer randomly jumps around the screen and no matter what resolution I use, where I shoot the screen, I just can't get it to work.
I did notice that where I shoot the screen makes a difference. I'm going to keep trying to get it calibrated, but any help from you guys would be appreciated.
jozhua
  • Last login:August 16, 2009, 02:03:49 am
« Reply #4 on: January 03, 2009, 06:16:37 pm »
I fixed yuff's problem with this. It was as simple as turning off his ceiling fan! I guess the wind was bouncing around the IR waves? ???
jeffremiller
  • Last login:January 03, 2011, 05:55:16 pm
  • No matter where you go... There you are...
« Reply #5 on: January 03, 2009, 10:59:01 pm »
If that is the case... then there is little hope for these guns.
I paid full price for two of the version 1 models... NEVER got them to work worth a crap and sold both for less than the price of one.
I wish everyone luck...but for God's sake.... how many horror stories does it take?
People keep buying these?
"If all wishes were gratified, many dreams would be destroyed." - B. Banzai
yuff
« Reply #6 on: January 04, 2009, 12:16:50 pm »
The problem I think is the fan+light on the fan combo. I turned the fan back on after jozhua left, and it still worked fine. The fan was probably bouncing some weird reflections onto the lcd screen. It really works great now!
vetteguy112233
« Reply #7 on: January 04, 2009, 02:09:15 pm »
Also see my thread about calibration issues. Hope it helps.
http://forum.arcadecontrols.com/index.php?topic=88094.0
