Author Topic: Cutting holes for speakers  (Read 2869 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: December 29, 2008, 09:50:35 pm »
My cab is in it's final stages.  One of the finishing touches I've been putting off is cutting slots for the speakers.  I've come up with 2 solutions and I'm hoping for some input.  The first is oval slots like in the classic machines.  It's a series of maybe 6 or 7 slots that start small and gradually increase in size then decrease to make a circle.  This might be difficult to do because the cab is assembled.  I do have a router but I think it will be difficult to get it in place and I don't know how to make those exact cuts.  My second much simpler idea is just to drill a series of maybe 1/2" holes that create a circle.  Like a grill but in the wood.  I've seen people mount an actual grill on the outside but I want it to look a little more classic.  Thanks.
Ed.
Lecithin
  • Last login:April 04, 2012, 10:15:48 am
Re: Cutting holes for speakers
« Reply #1 on: December 31, 2008, 08:49:19 am »
Why not go with the first option but use a jigsaw? They tend to have a smaller footprint then routers (you may have to sand/file to get the curves perfect). If you can't fit the router or have the experience with it then I a well done option #2 will look and work great as well. Good luck!
severdhed
  • Last login:November 28, 2025, 05:08:06 pm
  • RIP Dinosaur Hippo
« Reply #2 on: December 31, 2008, 12:10:16 pm »
you can pick up a trim router at harbor freight for about $25, they are much smaller than a regular router and may get into that tight space better.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=44914
i just got one of these from my wife for Christmas...havent had a chance to use it yet though. (i learned my lesson...never use a router indoors, unless you want to be cleaning sawdust off of everything for the next 6 months)
ivwshane
    • My first mame cab! (WIP)
« Reply #3 on: January 01, 2009, 01:29:17 am »
If your speaker shelf is already in place then doing either may be very difficult. I'd personally just cut out a square and fill it with a mesh grill.
shredso
« Reply #4 on: January 02, 2009, 11:15:01 am »
I can hear the speakers fine with no holes cut, I may just leave it that way.
dkubarek
  • Last login:February 25, 2011, 01:00:32 am
« Reply #5 on: January 04, 2009, 12:00:38 am »
Shredso, I'm in a similar situation. Due to my faulty design I didn't leave much room for speakers. I was planning to mount them in the marquis and drill small holes in the plexiglass but I'm not the best at drilling plexiglass. I might try not drilling holes now. I'll practice on a spare piece and go from there. But I'll make sure it makes a difference. I'm assuming it would be better to have holes, but I've left part of the back open, so I doubt I'll get too much distortion.
shredso
« Reply #6 on: January 04, 2009, 01:06:17 pm »
I cant picture drilling holes through the marquee.  If you had a lit marquee I think light would show through and it might look funny.  I also have the back open and I'm 99% sure I'm gonna settle for no speaker holes because it sounds fine.  My marquee is back from printing Tuesday and if I can just figure out a way to mount my bezel I'm 100%!!
