Author Topic: D9200 in golden Tee Red goes out.(what transistors runs red?)  (Read 2946 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: December 24, 2008, 09:05:07 pm »
Merry Christmas All
I have a D9200 in a 05 Golden Tee. I lost the red a year ago. I changed neck board and it worked. Now it did it again.
Any thing I should know. I don't like $60.00 fuses.
« Last Edit: December 29, 2008, 05:29:41 pm by fairway2000 »
Ken Layton
  • Guru
  • Technician
Re: D9200 in golden Tee Red goes out
« Reply #1 on: December 24, 2008, 10:23:56 pm »
This service bulletin explains what has happened and how to repair it:
http://www.wellsgardner.com/pdf/Service/SERVICE%20BULLETIN%2030A%20NECK.pdf
fairway2000
« Reply #2 on: December 24, 2008, 10:31:03 pm »
I have the new board.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 24, 2008, 11:16:23 pm »
Resolder or replace the red driver transistor on the neckboard.
fairway2000
« Reply #4 on: December 25, 2008, 10:21:18 am »
Thanks Ken
The Red came back. Could that still be the problem?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: December 25, 2008, 12:14:56 pm »
I had the same exact "RED disappears" problem on a Golden Tee on location and it had the new neckboard too. I resoldered the transistor, but the problem became intermittent.....sometimes working, sometimes not. Ended up swapping that transistor with one of the other colors and the problem moved to the other color. So I went out and bought a brand new NTE replacement transistor and that fixed it. Remember these transistors are driven very hard to the limit of their specifications (part of Wells-Gardner's poor design) and fail often from heat. Use silicone heat sink grease on these transistors.
fairway2000
« Reply #6 on: December 27, 2008, 05:23:22 pm »
Is that Q 201? I have an old style neck board can I take it off that? Or is that the one thing they changed.
Thanks Again
Ken Layton
  • Guru
  • Technician
« Reply #7 on: December 27, 2008, 05:29:57 pm »
I don't have a manual or schematic. I don't think the newer neckboard used different transistors than the old one. I think only the layout and the method of mounting the transistor changed.
fairway2000
Re: D9200 in golden Tee Red goes out.(what transistors runs red?)
« Reply #8 on: December 29, 2008, 05:34:28 pm »
Ok I have two manuals one said Q202 and the other said 211? Help
grantspain
« Reply #9 on: December 29, 2008, 05:43:07 pm »
q201 and q203 according to the schem
fairway2000
« Reply #10 on: December 29, 2008, 07:53:08 pm »
 Ok I changed Q201 and it works. Now I have done this 3 times on this game. Can you drive the red too hard? I have 4 games in my house with a D9200 and this one is the only one that does it.
Thanks for the help
« Last Edit: December 29, 2008, 07:55:46 pm by fairway2000 »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #11 on: December 29, 2008, 08:33:59 pm »
i assume u replaced it with a new xistor  AND applied heatsink compound.
and from Ken's prev post:
there has been a modification/production change made to the circuitry/pcb.
using orig pcb or upgrade ?
qrz
fairway2000
« Reply #12 on: December 30, 2008, 06:15:23 pm »
Yep did all that. I did mount a fan in the machine. I saw my Blitz has 4 fans and never had a problem
