Author Topic: D9200 problem/issue  (Read 2286 times)
PkingRoch
  • Last login:June 08, 2020, 02:12:47 pm
  • This is supposed to be fun...
    • Paul & Brian's Arcade Adventure
D9200 problem/issue
« on: June 21, 2003, 11:31:40 am »
I was able to mount my monitor last night and hook it up for some make-shift playing and I had a problem almost immediately.  The monitor kept flashing on and off.  This only seemed to happen in 800x600 and it didn't matter if I was in MAME or Windows XP.  640x480 worked great for MAME, but it makes Windows XP pretty difficult to use and that is a must.  This monitor is brand new, so it should be fixed free of charge, but I was wondering if anyone had seen this before.  I thought the video card might be suspect, but it worked just fine on a computer monitor.
Paul
PkingRoch
Re:D9200 problem/issue
« Reply #1 on: June 21, 2003, 01:24:29 pm »
OK - so it might now be the monitor.
I have hooked my laptop up to the monitor, set the resolution ato 800x600 at 60hz and the monitor has been flawless.
Could it be the video card? I know it's a cheap GeForce based off-brand card (ACO MX-400).  Has anyone had issues with this?
Paul
infariot25
  • Last login:March 13, 2012, 01:16:44 am
    • Nerd Palace
« Reply #2 on: June 22, 2003, 03:03:07 am »
i have a d9200 and i use a (pulled from a compaq presario)geforce 2 mx440(?).  I haven't had problems with 800x600.  I use 640x480 anyway.. 800x600 is blurry and tough to read.
PkingRoch
« Reply #3 on: June 22, 2003, 08:24:29 am »
Well something was a little strange.  When I tried again yesterday, the card drove the monitor without a problem, not a flash in sight.  I have a one-year to figure it out I guess.
Paul
PkingRoch
« Reply #4 on: June 23, 2003, 02:35:51 pm »
Well, looks like the problem is back (I should have known better).  Any ideas on this one?
StephenH
  • Last login:January 09, 2023, 06:15:45 am
« Reply #5 on: June 24, 2003, 01:13:52 am »
Try setting your video mode to 60Hz when running at 800x600.
PkingRoch
« Reply #6 on: June 24, 2003, 10:09:36 am »
It is set to 800x600 at 60Hz.  It starts out OK, but the longer you stay at that resolution, the more it flashes off.
