Author Topic: SK Jukebox not seeing all song files  (Read 2323 times)
digitaldj
« on: December 13, 2008, 06:52:36 pm »
Has anyone had an issue with SK Jukebox not seeing all song files?
 iI have mine a music folder that is organised by Genre then down to artist & album folders?
The way I found that it wasn't seeing all songs is watching what comes up when SK loads and checking my properties in my music folder and the number was different!
Thanks,
Kevin
gonzo90017
Re: SK Jukebox not seeing all song files
« Reply #1 on: December 14, 2008, 12:33:06 am »
Are you using a static database? If "Directories> Use Static Database" is unchecked make sure you click on "Update Database" any time you add new music to your collection. Also are you sure the reason you have more files then you think is because you're also counting your folder.jpg's?
digitaldj
« Reply #2 on: December 15, 2008, 01:13:57 pm »
Actually I never thought about the jpegs. I will also check on the static database also.
Thanks,
Kevin
