Author Topic: Alot of single MP3's to auto organise to folders  (Read 2376 times)
digitaldj
« on: December 13, 2008, 06:47:04 pm »
Hello All!
Is there a program out there that can auto organize single mp3 files into artist folders?
Thanks,
Kevin
justtaint
  • Last login:September 08, 2021, 06:11:05 pm
Re: Alot of single MP3's to auto organise to folders
« Reply #1 on: December 19, 2008, 09:30:47 am »
Tag & Rename
On the Rename Files tab
For File Name Mask, type "%1\%1 - %2" without the " "
And it will create folders for every artist and rename the songs to Artist - Title
If you want to include any other data, just choose the applicable variable.
justtaint
« Reply #2 on: December 19, 2008, 09:31:12 am »
That's assuming you have the proper ID3 tags.
nipsmg
  • Last login:January 20, 2026, 10:46:56 am
  • ROONEY!! ERRGH!!
    • Arcadia
« Reply #3 on: December 19, 2008, 11:45:47 am »
Well, the good think about T&R is that you can also fill the tags from the filenames by creating a format string for selected files.
so if you have a whole bunch of files that are like (Artist) - Title.mp3, you can create a format string like (%1) - %2.mp3 and have the values filled in.  If not, then get to work on the tags, you really need a clean library with tags to do useful stuff with your music.
sirk123au
  • Last login:May 11, 2011, 04:21:50 am
« Reply #4 on: January 10, 2009, 08:09:57 pm »
You Could Try TGF(The Godfather) Its a bit more advanced but it does a great job
