Author Topic: Wells K7500 - top half is dark  (Read 4489 times)
jconstanza
  • Last login:April 23, 2009, 02:28:02 pm
« on: December 04, 2008, 05:38:58 pm »
Working on a Wells Gardner K7500 that has the top half of the screen darker than the bottom. Tried swapping U601 (TDA1771) and U701 (LA7851), same thing. Am I looking in the right places?
grantspain
Re: Wells K7500 - top half is dark
« Reply #1 on: December 04, 2008, 05:44:24 pm »
got a pic of the prob
jconstanza
« Reply #2 on: December 04, 2008, 05:53:52 pm »
Here you go
grantspain
« Reply #3 on: December 04, 2008, 05:57:26 pm »
whats your input source to this?
jconstanza
« Reply #4 on: December 04, 2008, 06:01:28 pm »
Well I have it on a wells pattern generator right now, but it came out of a Hydro Thunder
grantspain
« Reply #5 on: December 04, 2008, 06:20:11 pm »
the generator is giving this a 15khz signal?
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #6 on: December 04, 2008, 06:22:47 pm »
That's a weird one.
Just for giggles, check R101 and see if it's open.
grantspain
« Reply #7 on: December 04, 2008, 06:37:42 pm »
looks like a problem with the vertical sync or a frequency issue
sarge
  • Last login:April 27, 2015, 01:42:54 pm
« Reply #8 on: December 04, 2008, 09:02:14 pm »
what happens when you adjust the vertical size?
Arm123
  • Last login:March 03, 2025, 11:26:20 am
« Reply #9 on: December 05, 2008, 12:35:38 am »
I had a similar problem with a K7000 that had half the screen darkened, but split vertically.  Never got around to looking at it again. Interested in hearing your solution.
jconstanza
« Reply #10 on: December 05, 2008, 09:21:35 am »
15khz not sure? I have it set to EGA on the generator. R101 is not open.  I use only my multimeter to troubleshoot. I do have an oscilliscope, but no clue on how to use it. Can I measure khz with my meter?
grantspain
« Reply #11 on: December 05, 2008, 09:49:26 am »
well if the generator is set to ega/24khz then the signal is fine
the vertical hold or sync is the only thing i have ever seen cause this
do you have an option for sync polarity on the generator?
SirPeale
« Reply #12 on: December 05, 2008, 09:49:59 am »
Smoothing cap - 47uf, 160V @ C57.
jconstanza
« Reply #13 on: December 05, 2008, 10:10:03 am »
No, no option for that.
jconstanza
« Reply #14 on: December 05, 2008, 10:17:39 am »
C57?
grantspain
« Reply #15 on: December 05, 2008, 01:05:29 pm »
and you have the same problem in the cab?
jconstanza
« Reply #16 on: December 05, 2008, 01:48:55 pm »
Yes
grantspain
« Reply #17 on: December 05, 2008, 02:07:30 pm »
well thats good(in a way) as it rules out frequency
have you followed the wg repair guide on this?
jconstanza
« Reply #18 on: December 05, 2008, 02:23:35 pm »
Ehh, not completely. It's tough cause I don't have all the parts that they are pointing out
SirPeale
« Reply #19 on: December 05, 2008, 02:59:09 pm »
C57?
That was a response to the guy who had the problem with his K7000.
grantspain
« Reply #20 on: December 05, 2008, 03:07:32 pm »
from wg guide
SCREEN BLACK ON ONE SIDE
 BLACK WIRE ON FLYBACK REVERSED
 C310, C812
i had a similar fault on a few polo monitor caused by a resistor on the g1 circuit.its equal on the k7500 is r545 150ohm
jconstanza
« Reply #21 on: December 10, 2008, 02:39:25 pm »
Wow! I feel like an idiot. I got it like this from the customer. It had the wrong controller board.
grantspain
« Reply #22 on: December 10, 2008, 02:49:21 pm »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #23 on: December 12, 2008, 07:37:38 pm »
so much "fun" when someone has been in 'em.
recently had a serv call on an RCA projo. the hv splitter was arcing ( AND in the wrong place - HUH ??)
seems another "shop" had replaced the red crt , and didn't put the block back where it belonged,
 misrouted ctl/spkrs lines and didn't reinstall a number of screws.  ::)
hauled the chassis back to shop to undo all the damage ....
qrz
