Author Topic: Problem with artwork...  (Read 3459 times)
apoptygma
  • Last login:December 04, 2008, 09:18:01 pm
« on: December 04, 2008, 05:01:44 pm »
I've downloaded packs of snes and genesis snapshots for use in mala, but the files are all named as hashes not rom names, do i configure mala to look for hashes or do I rename them?
apoptygma
Re: Problem with artwork...
« Reply #1 on: December 04, 2008, 05:05:52 pm »
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #2 on: December 04, 2008, 05:28:03 pm »
you may need to try this utility:
http://www.waste.org/~winkles/fuzzyRename/
if the art files are similarly named as the rom files are, otherwise there may be a dat file that you can load into romcenter that'll bulk rename things for you.
apoptygma
« Reply #3 on: December 04, 2008, 05:53:08 pm »
no they are all named as CRC's eg one that appears to be shinobi is 0B6D3EB5.png and mortal kombat is 1AA3A207.png
apoptygma
« Reply #4 on: December 04, 2008, 06:04:33 pm »
It's ok, did a bit of digging and found "No-intro Image Renamer" and "RomCentre" which in combination do the trick flawlessly
Sardu
  • Last login:April 08, 2023, 05:45:54 pm
« Reply #5 on: December 04, 2008, 10:27:25 pm »
have you tried the screenshots from here?
http://localarcade.com/screenshotarchive/screenshots.htm
They use the goodtools naming standard.
