December 05, 2025, 08:17:01 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Well, that was weird. Outage sorted out. Thank you SirWoogie for saving the day!
Main
Monitor/Video Forum
Light Bulb trick on a Kortek 2914F. Anybody??
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Light Bulb trick on a Kortek 2914F. Anybody?? (Read 3644 times)
jconstanza
Trade Count:
0
Full Member
Offline
Last login:April 23, 2009, 02:28:02 pm
on:
December 01, 2008, 01:00:35 pm »
Does anybody know how to do the light bulb trick on a Kortek KT-2914F chassis?
Logged
grantspain
I personally prefer "bog trotter"
Trade Count:
+1
Full Member
Offline
Last login:August 16, 2025, 04:42:10 am
Re: Light Bulb trick on a Kortek 2914F. Anybody??
Reply #1 on:
December 01, 2008, 01:13:07 pm »
got a link to the schematic?
Logged
MonMotha
Trade Count:
+2
Full Member
Offline
Last login:February 19, 2018, 05:45:54 pm
Reply #2 on:
December 01, 2008, 02:10:52 pm »
http://www.retroblast.com/files/KT-XX14X-SM.pdf
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #3 on:
December 01, 2008, 02:40:46 pm »
whats the problem?
Logged
Arm123
Trade Count:
+2
Full Member
Offline
Last login:March 03, 2025, 11:26:20 am
Reply #4 on:
December 01, 2008, 02:48:23 pm »
I think he means the test of the high voltage section of the chassis... ?
Logged
jconstanza
Trade Count:
0
Full Member
Offline
Reply #5 on:
December 01, 2008, 03:23:01 pm »
Well I was trying to isolate the power supply because of the ticking noise I have coming from TH101. Here's what happen, I did a cap kit on it and stupidly reversed the cap on C615. I know it worked but after the cap popped then it started ticking. Idiot!
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #6 on:
December 01, 2008, 03:31:48 pm »
you would need to check diodes mate
D104,D105,D106
D108,IC103,IC101
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #7 on:
December 01, 2008, 03:33:44 pm »
its difficult to see with the schem but you have killed a voltage,that repair guide is good so follow that
i bet you were trying to get rid of your whistle
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #8 on:
December 01, 2008, 04:05:00 pm »
i am pretty sure to isolate the high voltage/flyback you need to desolder pins 1 and 6 of the flyback
bulb connect to chassis frame/ground and L106
i am sure the b+ on these multi syncs runs around 80v
would like someone to concur with this before you attempt this though
Logged
jconstanza
Trade Count:
0
Full Member
Offline
Reply #9 on:
December 01, 2008, 04:48:04 pm »
I replaced all those parts and still no luck. This monitor doesn't tick like the wells or neotec usually tick where all you here is just the tick. This one sort of actually turns on then off to the point where you can
see
something on the screen.
Logged
grantspain
Trade Count:
+1
Full Member
Offline
Reply #10 on:
December 01, 2008, 05:02:27 pm »
you will need to go through all those components on the line of the cap that was reversed,there are test points to check voltages
those multi syncs also do this if the signal frequency or sync are not stable
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
