Author Topic: Mala crash on startup after video intro  (Read 4312 times)
bsweet0us
  • Last login:December 18, 2020, 09:59:46 am
« on: November 30, 2008, 09:52:12 am »
Just launched Mala again after quite a hiatus and it seems to be crashing once I get into the gamelist.  Here's the log that generates from launch to crash...
2008/11/30  08:31:30.93   Info: Starting MaLa 1.0.5.8
2008/11/30  08:31:30.93   Info: Check plugin directory: E:\Emulators\Mala\plugins
2008/11/30  08:31:30.93   Info: Collecting event plugins (*.mplugin) in E:\Emulators\Mala\plugins\
2008/11/30  08:31:30.93   Info: Found event plugin UltraStikMapPlugin.mplugin
2008/11/30  08:31:30.93   Info: Event plugin UltraStikMapPlugin.mplugin loaded
2008/11/30  08:31:30.93   Info: Function: PluginName found
2008/11/30  08:31:30.93   Info: Function: PluginCopyright found
2008/11/30  08:31:30.93   Info: Event Function: MaLaGameSelected found
2008/11/30  08:31:30.93   Info: Event Function: MaLaEmulatorSelected not found
2008/11/30  08:31:30.93   Info: Event Function: MaLaListSelected not found
2008/11/30  08:31:30.93   Info: Event Function: MaLaOrientationSwitch not found
2008/11/30  08:31:30.93   Info: Event Function: MaLaScreensaverStart not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaScreensaverSwitch not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaScreensaverStop not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaAttractModeStart not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaAttractModeStop not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaGameStart found
2008/11/30  08:31:30.95   Info: Event Function: MaLaGameQuit found
2008/11/30  08:31:30.95   Info: Event Function: MaLaStart found
2008/11/30  08:31:30.95   Info: Event Function: MaLaQuit found
2008/11/30  08:31:30.95   Info: Event Function: MaLaTreeUp not found
2008/11/30  08:31:30.95   Info: Event Function: MaLaTreeDown not found
2008/11/30  08:31:30.95   Info: Event Function: PluginConfigure not found
2008/11/30  08:31:30.95   Info: Check backup directory: E:\Emulators\Mala\backups
2008/11/30  08:31:30.95   Info: Check to see if hook dll is required
2008/11/30  08:31:30.95   Info: Win98/ME Hook dll not loaded because OS is: WinXP
2008/11/30  08:31:31.18   Info: Loading config params from ini file
2008/11/30  08:31:31.26   Info: Setting params from ini file
2008/11/30  08:31:31.28   Info: Creating and loading mame cl conditions: E:\Emulators\Mala\mame.clc
2008/11/30  08:31:31.28   Info: Creating and loading mame info pages: E:\Emulators\Mala\mame.mli
2008/11/30  08:31:31.28   Info: Creating and loading other emu info pages: E:\Emulators\Mala\otheremu.mli
2008/11/30  08:31:31.28   Info: Creating and loading filter sets: E:\Emulators\Mala\mala.mlf
2008/11/30  08:31:31.28   Info: Creating and loading non mame emulators: E:\Emulators\Mala\mala.mle
2008/11/30  08:31:31.28   Info: Creating and loading layout ...
2008/11/30  08:31:31.28   Info: Collecting layout files (*.mll) in E:\Emulators\Mala\layouts\
2008/11/30  08:31:31.28   Info: Creating and loading mala tree
2008/11/30  08:31:31.28   Info: Collecting game list files (mlg) in E:\Emulators\Mala\
2008/11/30  08:31:31.28   Info: Creating and loading bios
2008/11/30  08:31:31.29   Info: Hiding taskbar
2008/11/30  08:31:31.37   Info: Creating audio object
2008/11/30  08:31:31.62   Info: Creating and loading mala lcd screens
2008/11/30  08:31:31.62   Info: Creating and loading mame lcd screens
2008/11/30  08:31:31.65   Info: Creating and loading jukebox lcd screens
2008/11/30  08:31:31.67   Info: Creating and loading led config and attroct mode list
2008/11/30  08:31:31.67   Info: Collecting attract mode files (*.mlc) in E:\Emulators\Mala\
2008/11/30  08:31:31.67   Info: Loading game list: E:\Emulators\Mala\My games.mlg
2008/11/30  08:31:31.71   Info: Loading layout: E:\Emulators\Mala\layouts\pixas_1024.mll
2008/11/30  08:31:32.10   Info: Changing resolution to 800x600x32
2008/11/30  08:31:36.90   Info: Screensaver: KeyDown Detected
2008/11/30  08:31:36.90   Info: Screensaver: Screensaver stopping ****
2008/11/30  08:31:36.92   Info: Screensaver: Hide Window
Then the Mala has encountered a problem and needs to close box pops up.  Viewing more information about the error gives me this:
Appname: mala.exe AppVer: 1.0.5.8 ModName: mala.exe
ModVer: 1.0.5.8 Offset: 0010c10e
Redownloaded the newest version and reinstalled with no effect on this error.
Any suggestions?
loadman
    • MaLa
Re: Mala crash on startup after video intro
« Reply #1 on: November 30, 2008, 05:27:56 pm »
If you edit mala.ini to turn off the startup video do you still have the issue?
bsweet0us
« Reply #2 on: November 30, 2008, 11:37:57 pm »
No, seems to work fine with the startup video disabled.  Not really necessary for me, but is there a workaround/fix?
loadman
    • MaLa
« Reply #3 on: December 01, 2008, 12:45:46 am »
Well it does not happen to me and I have not heard of it being reported before, so I can't offer a fix with the details I have so far.
Can you try another vid?
What Codec are you using?
bsweet0us
« Reply #4 on: December 01, 2008, 07:30:24 am »
Same crash with a different video.
As far as I know, I'm using the XVID codec.  My video previews when in MALA work and games will start and run as expected.  Seems to just be a hiccup with the startup video.  I know codecs messed with MALA in early development and XVID seemed to be the only one it would play nice with, but I can't imagine it would play previews fine and not the startup video.
Then again, I'm no expert on this, that's why I posted here!
Anywho, if you've got some suggestions, let me know and I'll try them out.  THANKS!
loadman
    • MaLa
« Reply #5 on: December 02, 2008, 05:14:36 am »
Umm Is Mouse enabled in MaLa?
bsweet0us
« Reply #6 on: December 02, 2008, 07:48:58 am »
Usemouse is set to 0....didn't see any other mention of he mouse in mala.ini, so I;m assuming no?
garykagan
  • No-Edit-Allowed
  • Last login:April 30, 2011, 10:56:49 am
« Reply #7 on: May 28, 2009, 12:13:58 am »
It's the codec for sure.  I downloaded the latest from www.xvidmovies.com/codec/ and it started working instantly.
garykagan
  • No-Edit-Allowed
« Reply #8 on: May 28, 2009, 12:17:03 am »
just a note on this - I had a problem with all videos not starting....until the codec was installed.  As for the startup video that is something else....sorry...
