Author Topic: Getting Attract Videos to just play once...  (Read 2471 times)
PsychoAU
  • Last login:October 04, 2020, 12:27:19 am
« on: November 28, 2008, 01:51:56 pm »
I just set up MaLa to use the emumovies video previews of the games.  Is there a way to just have the attract videos just play once and then go back to the snap (which is under it) instead of looping?  I have the sound enabled and if I leave MaLa idle, it will just play the video over and over and over.  I would like it to just play once, so if the front end is idle, then it won't loop forever.
Otherwise, it looks like I am going to have to disable the attract video sound so it is not playing the sound over and over while my screensaver is active...
« Last Edit: November 28, 2008, 02:07:08 pm by PsychoAU »
loadman
  • Moderator
    • MaLa
Re: Getting Attract Videos to just play once...
« Reply #1 on: November 28, 2008, 10:19:31 pm »
No,
But I will put your suggestion on the tod-do list as that won't be too hard to impliment  ;)
