Author Topic: For Sale: Ultimarc OptiPAC + Suzo trackball (in EU)  (Read 1477 times)
Allan Bernard
  • Last login:December 06, 2008, 02:17:34 am
« on: November 26, 2008, 02:21:44 am »
All stuff slightly used but in perfect working condition.
Will ship worldwide (although it would be more sensible for someone in the EU - since this way there will be no VAT).
Local pickup possible.
The Opti-PAC (Optical Interface for Pc to Arcade Controls) is an interface for easily connecting optical-type arcade control devices including trackballs and spinners to a PC for use with emulators such as MAME.
More information: http://ultimarc.com/optipac1.html
For sale:
Opti-PAC board, PCB mounting feet, USB cable.
Price: 35.- USD (New set at ultimarc's store 47 USD)
A High Quality 2 1/4 inch (57mm) Trackball assembly. Uses a heavyweight solid (non-translucent) "pool ball" type ball with ball bearing mounted rollers. Same hole mounting pattern as Happ trackballs. Supplied with wiring harnesses for connection to Opti-PAC.
Mounting plate for above trackball. Finished in black hammerite. Allows quick and neat mounting of trackball into panel, with no visible screw-heads etc on the top surface. Especially recommended for wood panels where trackball mounting is difficult. Supplied with all mounting screws and nuts.
More information: http://ultimarc.com/controls.html
For sale:
Suzo 2 1/4" trackball ("Ultimarc trackball"), mounting plate, adaptor harness for Opti-Pac.
Price: 55.- USD (New set at ultimarc's store 67 USD)
So when bought together a complete trackball set, ready to be mounted to any panel and connected to a PC. (Also another trackball and two spinners can be connected to the same board).
Both things together:
90 USD + shipping (you save 24 USD)
Allan Bernard
GSM: (+372) 55 632 698
Tallinn, Estonia, Europe
