Author Topic: Safe Key Presses  (Read 852 times)
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
Safe Key Presses
« on: November 20, 2008, 09:00:34 am »
It seems like every time I think I have it all figured out, there is another bend in the road.
Is there a general rule of thumb for safe keys to use when configuring a control panel?
I though I had it all covered but I have since run into two issues with the following emus.
SSF (Saturn Emulator) - Problem - Num Lock Keys can not be used for control commands.
Visual Pinball - Problem - Key Press 4 cannot be reconfigured from coin insert
So my lesson so far is this, don't use num lock keys or number keys.
It would assume that function keys would be a bad choice as well as well as common used letters like “p” for pause.
Is there a general rule of thumb here? What works and what doesn’t? It would be cool to start some sorta data base for something like this…
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
