Author Topic: Mala problem at start-up  (Read 2109 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: November 19, 2008, 12:34:33 am »
I am using the latest beta of Mala with Win 2000.  I put a shortcut into the Start-up file to launch Mala when I turn on the computer.  It boots up fine but I cannot do anything in the menu.  I have to right-click on my mouse first then I get Mala working.  Is this a focus issue?  I tried the plug-in and it didn't work.  Should I have Mala start through it's own option screens instead of the shortcut?
Thanks,
Southpaw
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Mala problem at start-up
« Reply #1 on: November 19, 2008, 04:20:00 am »
If you are trying to run it in a cab and hiding windows I would use instant sheller, this should solve your problem
loadman
    • MaLa
« Reply #2 on: November 19, 2008, 05:43:27 am »
another think to try
Something else that is startring up is stealing focus.
You can try setting 10000 ot higher as the 'splash time' in options to see if that helps
It is in gui-display-misc
« Last Edit: November 19, 2008, 05:45:08 am by loadman »
southpaw13
  • Whatever!
« Reply #3 on: November 19, 2008, 10:09:46 am »
And that's why I love this front end...there is a option for everyone....
Problem solved....
Thanks again,
Southpaw
