Author Topic: AdvanceMenu - DOS Vertical Monitor Marquee View Issue  (Read 1134 times)
EagleTG
  • Last login:July 21, 2016, 08:01:34 pm
« on: November 18, 2008, 02:48:33 pm »
Anyone else seeing an issue with squished Marquees when using AdvanceMenu from DOS and trying to rotate for a vertical monitor?  I'd love to use the simple Marquee interface, but this bug is driving me crazy.  I've tried resizing my marquees, rotating them to compensate, endless iterations of reconfiguration... I still can't get this to work quite right.  If it matters, I'm running it on FreeDOS.
I see a note in the release history from the 1.18 version that indicates "Fixed the aspect of the marquee images with vertical monitors".  I'm not sure if this bug creeped back into the later versions, or possibly was never properly addressed in the DOS build?
Thanks.
Ummon
  • Trade Count: (+13)
Re: AdvanceMenu - DOS Vertical Monitor Marquee View Issue
« Reply #1 on: November 18, 2008, 07:55:07 pm »
That's a mighty rare situation you're running, so answers may be non-existent. I wasn't ever able to get marquees to show up in the Windows version. The template would show, but no images in the boxes.
Yo. Chocolate.
Stephen Hawking
