Author Topic: Help me identify this 8-way trigger joystick...  (Read 2219 times)
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« on: November 16, 2008, 12:02:00 pm »
Does anyone recognize what game this 8-way trigger joystick was used for? I purchased it as NOS - it uses leaf switches. I'd like replace the handle with Randy's new Tron replacement handle - but I'm concerned the mounting screws won't work. The original Tron stick (and Randy's) has two screws holding the shell together through the shaft. My stick has a single screw through the shaft and appears to have two additional vertical screws at the bottom. I guess I could disassemble the stick, but I'd rather just find an exploded view - any idea's?
« Last Edit: November 16, 2008, 12:15:24 pm by arzoo »
Robots will kill you.
Arcade Addiction
Re: Help me identify this 8-way trigger joystick...
« Reply #1 on: November 16, 2008, 12:08:02 pm »
Looks like a Mach 3 stick to me
Ummon
  • Trade Count: (+13)
« Reply #2 on: November 16, 2008, 09:45:38 pm »
Yeah, same one I have. I only see the two screws underneath the bottom of the handle. Except for the mounting holes, the overall design is the same as the Tron/GGG/Happ handles. Maybe ask Randy if this will matter?
Yo. Chocolate.
Stephen Hawking
arzoo
    • LEDBlinky
« Reply #3 on: November 17, 2008, 02:33:47 pm »
Ummon,
I sent Randy an email, but he really needs a picture of our handle disassembled. For me to do that would be a royal pain in the *ss - I'll have to remove my panel, and undo all the wires to get the stick separated from the base. Any chance you could provide a picture?
Arcade Addiction
Ummon
« Reply #4 on: November 19, 2008, 12:40:14 am »
The thing is snapped together pretty tight. Have to be careful pulling it apart as the trigger and spring like to pop out.
Yo. Chocolate.
Stephen Hawking
arzoo
    • LEDBlinky
« Reply #5 on: November 19, 2008, 07:47:28 am »
Ummon,
Thanks for the pictures.  :cheers:
I see you also posted them on Randy's thread - unfortunately it doesn't look like our stick will work with his Tron handle.  :(
Arcade Addiction
