Author Topic: Mame32 - MKII and NBA Jam Sound issues  (Read 1442 times)
savj14
  • Last login:April 06, 2020, 07:52:46 pm
« on: November 14, 2008, 03:49:45 pm »
I am running Mame32 v106. My issue is when I run MKII the sound level is very low. I go into the Service Menu(F2) and Adjust the Volume. Get back into the game and it is fine. If I exit the game, and go back the sound is low again. So in short in order for the sound to be at the correct level, I always have to go into the Service menu.
Now if I try the latest Mame32 version, this does not happen. The sound level is just fine. The only problem with this version is NBA Jam has some sound issues, as well as a some lag. The sound level is fine, it just seems the quality is a bit off. It has a deeper pitch to it. For example the announcer just doesn't sound right, like he does using v106. His voice is deeper and seems to talk slower. The gameplay is also choppy at times as well. I don't have this issue with v106 either.
Has anyone else noticed this? Is there a fix for either MKII or NBA Jam? Or what version of Mame32 the MKII issue was fixed? I can try the first fixed version and see if NBA Jam sounds bad.
I am in quite a bind as I regularly play both of these games.
« Last Edit: November 14, 2008, 03:53:37 pm by savj14 »
