Author Topic: Tekken 3 in Mame solution :D  (Read 27015 times)
Xiaou2
  • Last login:January 25, 2026, 07:35:56 pm
  • NOM NOM NOM
« on: November 12, 2008, 09:17:22 pm »
 Today, I felt like checking to see if there was any new progress on the Tekken 3
series.
 I downloaded mameUIFX32 128u3.
 A few versions dont dis/play right at all.   However,  the ones that do have music and
sound that is too low of pitch.  It seems slow...
 I tried to overclock the two different CPUs to see if that would work... but I dont have
enough horsepower to know it it would work... cause I started to drop frames.
 However, I then used the option to adjust the frames displayed.  Changed from
60fps to 30.   The sound was nearly arcade perfect   ;D
 This only seemed to work on version E1 roms.
 Now, In my arcade days, I used to go into this game, and set it to "interlace" to get higher resolution mode.   However,  mame will not let you access that setting in the
operator options.  Why?
 Anyways... that is how I figures out the sound issue.
I figured that if the game ran interlace mode... it may have been running at a higher
framerate.    While that does not have to be the case... it just might be so in this
game/boardset.   A means to keep cost down by giving the option of extra crisp graphics
without the extra processor power needed.   Quite brilliant actually.
 I wonder if the Devs have realized this or not?   Maybe this info is out there for this
trick.. and I just was too lazy to find it out.    Happy fightin.  :)
Ummon
  • Trade Count: (+13)
Re: Tekken 3 in Mame solution :D
« Reply #1 on: November 12, 2008, 11:01:17 pm »
Might mention it at Mameworld.
Yo. Chocolate.
Stephen Hawking
Martijn
  • Akira!
    • ModMyBox
« Reply #2 on: November 13, 2008, 02:24:53 am »
i just use the playstation 1 emulator
tekken 1,2 and 3 work great, 99,9% accurate
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #3 on: November 13, 2008, 08:17:26 am »
Have you tried Blitz in that thing? :gobama
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
Flake
  • Last login:January 11, 2025, 01:16:20 pm
  • I am Evil Homer....I am Evil Homer....
« Reply #4 on: November 13, 2008, 12:18:41 pm »
What is a good play station 1 emulator?  Also, how do you map for 8 buttons?  (I think the controller had 8 buttons).
Visitor Q
  • The Saw Is Family
« Reply #5 on: November 13, 2008, 12:35:06 pm »
epsxe
TAG
  • Last login:May 23, 2014, 05:52:05 pm
« Reply #6 on: November 13, 2008, 01:11:37 pm »
I'm using pSX, and it runs great!  And if you're using it to play Tekken, you really shouldn't have to map more than 5 buttons (including start).
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
-- Dirk Gently
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« Reply #7 on: November 13, 2008, 01:22:17 pm »
You should also map the 2 shoulder (L + R) buttons as well. I map 6 buttons per player plus 2 starts to player 1 and 2 buttons, and two selects to my cab control buttons i.e. pause and UI control.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #8 on: November 13, 2008, 02:06:44 pm »
I'm really liking pSX so far. It does run great. Been using it about a month in my cab without a single complaint.
TAG
« Reply #9 on: November 13, 2008, 02:18:09 pm »
Right, forgot about the selects, but you don't need the separate L and R shoulder buttons for Playstation's Tekken, do you?  (of course, if you're playing other PS games on the cab, I suppose that's a moot point).  Just curious if I'm missing out on something.
-- Dirk Gently
Martijn
  • Akira!
    • ModMyBox
« Reply #10 on: November 13, 2008, 02:25:46 pm »
you should also try dreamcast emulation, its great ! dead or alive is lovely
TAG
« Reply #11 on: November 13, 2008, 02:32:54 pm »
Agreed.  NullDC is awesome and there are a lot of great arcade ports available for the Dreamcast.
-- Dirk Gently
Ginsu Victim
« Reply #12 on: November 13, 2008, 03:59:06 pm »
I have, but the PC in my cab won't run it. My main computer runs it great, though.
Flake
« Reply #13 on: November 13, 2008, 11:53:35 pm »
epsxe
I downloaded the latest version but I get an error sayingg cant find dill.dl or something like that - any suggestions?
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« Reply #14 on: November 14, 2008, 04:32:46 pm »
Or you could buy the board  >:D I did for Tekken 2, 3, Tag & 4  :cheers: Tekken 3 cost me something like $50.00
If You Are Going To Meddle At Least Listen
FrizzleFried
    • Idaho Garagecade
« Reply #15 on: November 14, 2008, 06:06:06 pm »
How easy is NullDC to setup in a cab?  Are the keys similarly mapped as MAME?   Will I have to remap anything with a JPAC?
BASS!
  • Just have fun.
« Reply #16 on: November 14, 2008, 07:25:52 pm »
It is strait up simple.
Go download or rip your dc games
Get the dreamcast boot and flash bin files
Configure your controls / display settings
Set up your memory cards
Point maximus arcade or whatever front end you use and blamo
Lemmie know if you need anything  ;)
BASS!
  • Just have fun.
« Reply #17 on: November 14, 2008, 07:28:07 pm »
You may want to download the older version and install the newer one on top of that. I have had a similar problem in an older version. You may also need to get your directx rutimes and copy them into the cfg folder.
epsxe
