Author Topic: Correct settings in mame.ini for AVGA card  (Read 5151 times)
sega_mad
  • Last login:July 09, 2015, 04:03:08 am
« on: November 11, 2008, 03:20:29 pm »
Hi, I'm running 2 versions of Mame. 102 & 114. I've set up 102 correctly as per the ultimarc website, but 114 doesn't have the same setting as 102, ie I can't put a 1 against direct draw. Would really appreciate some help on this one to get the full benefit of the AVGA card.
Thanks in advance :D
SparkyGoBlue
  • Last login:August 01, 2022, 04:06:45 am
Re: Correct settings in mame.ini for AVGA card
« Reply #1 on: November 11, 2008, 03:48:12 pm »
I don't use version 114, but I believe you just replace the d3d with ddraw under video in your mame ini to achieve what you're looking for.
sega_mad
« Reply #2 on: November 11, 2008, 03:53:26 pm »
Thanks for the reply, that's what I did last time, and some games (street fighter, but not all versions) went out of vertical sync.
Will give it another go.
Cheers
sega_mad
« Reply #3 on: November 11, 2008, 05:13:26 pm »
Ok, did that, but games like 1941 and 19XX (this is far as I've tested, I'm sure there are more) are not "syncing" up. I looked in the ini file and the res was 512 x 288.....seems a little out...any thoughts?
SailorSat
  • Last login:Yesterday at 11:07:22 pm
    • For Amusement Only e.V.
« Reply #4 on: November 12, 2008, 04:57:50 am »
1941 is a vertical game, and your monitor most likely is horizontal oriented, so the resolution won't match.
SparkyGoBlue
« Reply #5 on: November 12, 2008, 12:44:27 pm »
I don't have an AVGA card, but for vertical games, you may want to just set your resolution to 640x480 or 800x600 (if possible).
sega_mad
« Reply #6 on: November 12, 2008, 02:41:17 pm »
I'm running the monitor vertically, so all resolutions are correct. Spoke to Andy (from Ultimarc), and just tweaked the res in the INI file for each game that was playing up, and now she's all good.
Thanks for the help
sega_mad
« Reply #7 on: November 12, 2008, 02:45:56 pm »
Thanks, have it sorted now.
From what I can gather, if you are running the res at 640 X 480, then there is no point in using a AVGA card. The whole point of using an AVGA card is to get the resolutions exactly like the original games.
Ummon
  • Trade Count: (+13)
« Reply #8 on: November 14, 2008, 05:08:47 pm »
Thanks for the help
I bet if you'd understood (or read?) the Ultimarc monitor faq, not to mention the monitor section of the wiki, you would've been able to solve it yourself. Of course, it's so much easier, and reveals a lot about how things work, if one uses Mame32/UI when setting parametres, as you don't have to 'pull out of thin air' the values and such.
« Last Edit: November 14, 2008, 05:16:09 pm by Ummon »
Yo. Chocolate.
Stephen Hawking
