Author Topic: custom15khz.txt - Post your file?  (Read 5599 times)
Chase
  • Last login:November 13, 2020, 10:59:55 am
  • Live from Seattle!
    • Home
« on: November 10, 2008, 11:56:15 pm »
Hey Everyone,
I have Soft-15 installed and looking at tweaking and making my cabinet and machine look it's best!
But, I know I have to do some things, and was wondering if anyone had their "custom15khz.txt" file they could share?
my specs:
D9400 WG 27 Inch Monitor
ATI Radeon X600SE 128mb (Running 6.5)
Installed Soft-15KHz
Thanks for the help everyone,
Chase
ahofle
    • Arcade Ambience Project
Re: custom15khz.txt - Post your file?
« Reply #1 on: November 11, 2008, 11:16:43 am »
Try these two in custom25khz.txt (should work great with your multisync and newer shooters like DonPachi):
Modeline "432x324@60" 13.4 432 440 496 536 324 326 330 351 -hsync -vsync
Modeline "416x312@60" 13 416 424 480 520 312 314 318 338 -hsync -vsync
custom31khz.txt (add a full progressive 800x600):
modeline '800x600@60p' 40.0 800 840 968 1056 600 601 605 628 -hsync -vsync
usermodes.txt (interlaced 1024x768 and a 513 line modeline for Toobin and other vertical EGA games!):
modeline '1024x768@59,959i' 29,49 1024 1040 1136 1200 768 776 782 820 interlace -hsync -vsync
modeline "704x513@60p;31,5kHz" 29,484 704 752 840 936 513 517 523 525 -hsync -vsync
sham69
  • Last login:June 12, 2015, 06:03:44 am
« Reply #2 on: November 11, 2008, 12:27:10 pm »
Any chance of someone posting one to suit a radeon 9250 128mb card on a philips pal CRT tv
I am using soft 15khz and using a VGA-scary cable
Cheers
SailorSat
  • Last login:February 07, 2026, 07:38:58 pm
    • For Amusement Only e.V.
« Reply #3 on: November 11, 2008, 02:35:50 pm »
Custom15kHz.txt
modeline "pal-720x576@50i" 13.88 720 742 808 888 576 580 584 626 interlace -hsync -vsync
Custom25kHz.txt
modeline "daytona-496x384@60p" 15,4752 496 508 570 620 384 386 391 416 -hsync -vsync
modeline "cruisn-512x400@57p" 15,8688 512 576 640 640 400 404 408 435 -hsync -vsync
modeline "real-1024x768@60i" 29,50 1024 1040 1136 1200 768 776 782 820 interlace -hsync -vsync
« Last Edit: November 11, 2008, 02:41:12 pm by SailorSat »
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: November 12, 2008, 07:58:56 pm »
For some reason my GeForce 7200 doesn't like 320x256 mode... or any x256 modes... it drops out of 15khz (I can see a screen doubling) and the vhold goes apeshit.  Are there any custom modes anyone can recommend close to this that may work on an arcade monitor and this GeForce 7200.  Going to 320x240 cuts off the top score in Shuffleshot,  and World Class Bowling.
Ummon
  • Trade Count: (+13)
« Reply #5 on: November 12, 2008, 08:47:05 pm »
Frizz, WCB is 384x256. I think 320x256 is medium res.
Yo. Chocolate.
Stephen Hawking
FrizzleFried
    • Idaho Garagecade
« Reply #6 on: November 12, 2008, 11:16:27 pm »
That is what I meant.  It's the 256 vertical resolution that isn't working properly it seems... which isn't medium resolution. 416 x 384 is medium resolution... standard res goes up to 288 vertical lines.
EDIT - CORRECTION: This is only happening at 352x256 and 352x264.  It seems to basically jump to 31khz,  yet Soft15KHz is supposed to support it?!
« Last Edit: November 12, 2008, 11:35:58 pm by FrizzleFried »
ahofle
« Reply #7 on: November 13, 2008, 12:17:09 am »
That sounds like an issue with your card/driver if it's jumping to 31khz.  I had similar problems with 320x240 being line doubled 31khz.  I ended up using an older catalyst driver version and that solved it.
FrizzleFried
    • Idaho Garagecade
« Reply #8 on: November 13, 2008, 10:18:36 am »
I messed with it a little more and strangely,  instead of just DOUBLING the image (as it would if it were 31khz),  it's QUADRUPLING the image?!  Perhaps I'll try to re-install drivers...which is a huge pain in the ass being I am on XP x64.
How do I find older Windows XP x64 drivers I wonder.
SailorSat
« Reply #9 on: November 13, 2008, 05:22:30 pm »
most like you just need to tweak the modeline a bit.
those quad-screens are a pretty common problem with nvidia cards, though I don't know why it happens.
FrizzleFried
    • Idaho Garagecade
« Reply #10 on: November 14, 2008, 10:39:49 am »
....any suggestions for the "newb"?  Perhaps you can upload a couple modelines to try?  BTW: When i go to add them,  does it ADD whatever I put in the txt file or do I lose all resolutions BUT what's in the .txt file?
Ummon
« Reply #11 on: November 15, 2008, 12:58:34 am »
It depends. If it's custom**khz.txt and the resolution is the same as that in the stock set but the modeline is different, it puts the new one in place of the stock one. If it's completely different, I think it just adds it to the stock list. This can also be done using the usermodes.txt .
Yo. Chocolate.
Stephen Hawking
