Author Topic: Wanted: unpopulated circuit boards  (Read 1179 times)
jasonbar
  • Last login:January 11, 2026, 08:41:40 pm
  • Dr. Inferno
    • The Infernolab
« on: November 10, 2008, 05:08:13 pm »
Howdy-
I'm whipping up some geeky lightweight shelving & I need these to span across 2 bars & support just a few lb.
I need 4 circuit boards, preferably unpopulated, or perhaps populated somewhat evenly w/ low-profile items (I could remove handfuls of high items, but I don't want to strip an entire board...).
Size: about 10"x10".  Can be a bit bigger & I can cut it down.  Or I could use 8 skinner pieces that are 2-6" x 10" or so.
Some options I've come across so far:
http://cgi.ebay.com/Eight-8-Line-Video-Slots-Poker-Circuit-Board-LOT-1_W0QQitemZ120329156418QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item120329156418&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A15%7C39%3A1%7C240%3A1318
or
http://cgi.ebay.com/Eight-8-Line-Video-Slots-Poker-Circuit-Board-LOT-2_W0QQitemZ120329157089QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item120329157089&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A15%7C39%3A1%7C240%3A1318
or
http://cgi.ebay.com/GOLD-CIRCUIT-BOARDS-LONG-STRIPS_W0QQitemZ230305637223QQcmdZViewItemQQptZCoins_Bullion?hash=item230305637223&_trksid=p3286.c0.m14&_trkparms=66%3A4%7C65%3A15%7C39%3A1%7C240%3A1318
look as if they would do fine.
Or, I could go w/ those PCB 3-ring binders or clipboards or notebooks & hack them, though that would be a shame to bust up a finished product made from junk, when I actually just want the junk in the first place...  Actually, the 3-ring binder is probably a good option, as each one has 2 10.25"X11.5" panels that should be very easy to remove from the skinny central panel, which has all the binder hardware in it...
http://yhst-38838590695732.stores.yahoo.net/large-3ring-binde3.html
or
http://www.fractalspin.com/x/product.php?productid=66
or
Any other ideas?  Anybody got junked PCBS lying around that I can snag from ya?
Thanks,
-Jason
Re: Wanted: unpopulated circuit boards
« Reply #1 on: November 10, 2008, 05:15:44 pm »
If you don't find what you want here, you could always raid your local thrift store for older electronics and get what you need that way.  :)
« Reply #2 on: November 10, 2008, 06:55:05 pm »
Or do it free and raid your local town transfer station... they'll usually let you take electronics away free so long as you take it whole.
