Author Topic: u-hid nano wire  (Read 2283 times)
G1zm0
  • Last login:October 05, 2020, 06:57:58 am
  • cute by day, devil by night
u-hid nano wire
« on: November 10, 2008, 04:40:43 am »
wiring up a uhid nano, im using a hd cable as a harness but when i connect  uhid  to it and meater it out it buzzes.
i take u hid out and put 1 prob to one pin and the other to the other pins and they all buz as if there a short in the uhid, tryed this with 2 hids, is this normal
G1zm0
Re: u-hid nano wire
« Reply #1 on: November 12, 2008, 06:15:14 am »
i wire my uhid up with floppy wire, but when i use the joystick i get up up up and down, no wires are touching and when i meter the connections 3 buzz when i touch the common, im thinking of directly wiring to the uhid to connections.
also when i connect uhid to pc, the light stays green then goes out and config cant find it till i do a firmware update, then it looses the setting.
also having probs with shift keys, i select the secondary key, set it up, set shift key, try use it and nothing.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: u-hid nano wire
« Reply #2 on: November 12, 2008, 04:21:36 pm »
Seems like you might need to drop me an email and hopefully I can help
andy@ultimarc.com
