Author Topic: Help with Opti-Wiz  (Read 1323 times)
tevans333
  • Last login:February 18, 2011, 12:38:46 pm
Help with Opti-Wiz
« on: November 03, 2008, 02:23:57 pm »
Hi all, I have a driving cab with a 360 degree steering wheel. The wheel has the encoder disk on it but  none of the electronics. I believe that the opti-wiz is a good choice as an interface, especially since it is only $15:) But I have a few questions first to make sure I have it all figured out properly.
1) I need 2 opto sensors and a led for use with the encoder wheel?
2) The +5V and gnd on the opti-wiz can be used to power the above?
3) Just wire the 2 opto sensor outputs to the X-axis on the opti-wiz?
Thanks for any and all help,
Tim
mytymaus007
Re: Help with Opti-Wiz
« Reply #1 on: December 30, 2008, 08:43:28 pm »
sounds like it should work 360 wheel to optiwiz is it that simple, where do you get the opto sensors and led for the encoder on the wheel
Tim
Games001
  • Last login:January 13, 2024, 12:44:04 am
« Reply #2 on: December 30, 2008, 08:48:20 pm »
Actually, all you need to make a 360* Wheel, as long as it has an encoder wheel mounted, is this:
http://forum.arcadecontrols.com/index.php?topic=48855.0
Then use the Opti-Wiz as the controller.  +5v and Gnd all run to the same board.. simple.  You are basically wiring up a spinner that happens to have a wheel attached. :)
